wifi adapter
Posted: Wed May 06, 2015 9:33 am
by pratikprajapati
I am new to raspberry pi. I have raspberry pi 2 b with 1 gb ram.
I want to use usb wifi adpter to connect intrnet, but when i connect the wifi adpter to raspberry pi, it reboots.
the wifi adpter i am using is LB link , model number BL-WN151
http://www.lb-link.cn/index.php/products/view?pid=118
please help me
Re: wifi adapter
Posted: Wed May 06, 2015 1:11 pm
by MrEngman
pratikprajapati wrote:I am new to raspberry pi. I have raspberry pi 2 b with 1 gb ram.
please help me
When you connect the wifi adapter to your Pi is the power on or off? If you plug in the wifi while it is powered on your problem could be due to a poor quality power supply. What is the spec of the power supply? It could be a power supply problem but I could not say for certain. To avoid problems it is safest to turn off the power before connecting the wifi adapter.
I have an LB-Link BL-LW05-5R1 adapter and I have been able to get it to work on all 7 different versions of the Pi's I have, although I had to use a powered hub on my original Pi which has fuses on the USB power.
MrEngman
Re: wifi adapter
Posted: Wed May 06, 2015 7:35 pm
by pratikprajapati
Thanks for reply,
I am using adapter with 600mA current output. Will its enough to power the pi ?
Re: wifi adapter
Posted: Wed May 06, 2015 7:38 pm
by kusti8
600 ma is not enough for the pi and the USB. Get a good 2A power supply off Amazon.
Re: wifi adapter
Posted: Wed May 06, 2015 8:07 pm
by MrEngman
I have to agree with kusti8 that you need a much better power supply. 5v 2A would be ideal.
MrEngman
Re: wifi adapter
Posted: Wed May 06, 2015 8:10 pm
by fruitoftheloom
