cacophony555
Can't get USB drive to auto mount
Wed May 06, 2015 5:02 am
Short version: I can't get my new USB drive to mount automatically on boot, despite the fact that it mounts fine using "sudo mount -a".
Long version:
I have a new USB external hard drive plugged into my Pi 2. I created a mount directory and successfully formatted it to be EXT4 using :
sudo mkdir /mnt/usbdrive
sudo mkfs.ext4 /dev/sda1 -L downloads
I was then able to mount it manually using:
sudo mount /dev/sda1 /mnt/usbdrive
Next I wanted to get it to auto mount on fresh boot, so I added the following line to /etc/fstab:
/dev/sda1       /mnt/usbdrive   auto   defaults,user     0       1
But when I rebooted the drive wasn't mounted. So I tried this:
sudo mount -a
And that manual method worked to mount the drive. So next I tried changing fstab's "auto" part to "ext4".
But then I got an error on boot that prevented booting without manual intervention:
File system check failed. A log is being saved in /var/log/fsck/checkfs if that location is writeable. Please repair the file system manually...
The contents of /var/log/fsck/checkfs just has:
Log of fsck -C -R -A -y
Tue May 5 21:36:23 2015
fsck from util-linux 2.20.1
e2fsck 1.42.5 (29-Jul-2012)
fsck.ext4: No such file or directory while trying to open /dev/sda1
Possibly non-existent device?
dosfsck 3.0.13, 30 Jun 2012, FAT32, LFN
/dev/mmcblk0p1: 34 files, 1840/7161 clusters
fsck died with exit status 8
Not sure what it means, but I noticed that fdisk seems to categorize the drive as "HPFS/NTFS/exFAT":
[email protected] ~ $ sudo fdisk -l
Disk /dev/mmcblk0: 31.9 GB, 31914983424 bytes
4 heads, 16 sectors/track, 973968 cylinders, total 62333952 sectors
Units = sectors of 1 * 512 = 512 bytes
Sector size (logical/physical): 512 bytes / 512 bytes
I/O size (minimum/optimal): 512 bytes / 512 bytes
Disk identifier: 0x0009bf4f
        Device Boot      Start         End      Blocks   Id  System
/dev/mmcblk0p1            8192      122879       57344    c  W95 FAT32 (LBA)
/dev/mmcblk0p2          122880    62333951    31105536   83  Linux
Disk /dev/sda: 500.1 GB, 500074283008 bytes
255 heads, 63 sectors/track, 60797 cylinders, total 976707584 sectors
Disk identifier: 0xb78e8ac4
/dev/sda1            2048   976707583   488352768    7  HPFS/NTFS/exFAT
So I changed the fstab file to be "auto" so that the pi would fully boot again, but I still don't know why the drive isn't mounting automatically. Any help would be appreciated.
cacophony555
Re: Can't get USB drive to auto mount
Wed May 06, 2015 5:23 pm
There's also this output, which seems to indicate it is ext4:
[email protected] ~ $ sudo blkid -c /dev/null
/dev/mmcblk0p1: SEC_TYPE="msdos" LABEL="boot" UUID="140A-14B7" TYPE="vfat"
/dev/mmcblk0p2: UUID="f24a4949-f4b2-4cad-a780-a138695079ec" TYPE="ext4"
/dev/sda1: LABEL="downloads" UUID="dad3727d-6b29-4f64-b7be-abacc0c90a23" TYPE="ext4"
Wed May 06, 2015 7:20 pm
Try this
sudo blkid
Which should get something like
[email protected]:~$ sudo blkid
/dev/mmcblk0: PTUUID="0002c262" PTTYPE="dos"
/dev/mmcblk0p1: SEC_TYPE="msdos" LABEL="boot" UUID="24A3-1E5A" TYPE="vfat" PARTUUID="0002c262-01"
/dev/mmcblk0p2: UUID="548da502-ebde-45c0-9ab2-de5e2431ee0b" TYPE="ext4" PARTUUID="0002c262-02"
/dev/sda1: PARTLABEL="Microsoft reserved partition" PARTUUID="bb424d83-6547-4ade-bcc8-89caa2a04dc3"
/dev/sda2: UUID="8c83aad9-de40-4403-89df-9b6222b69827" TYPE="ext2" PARTLABEL="Basic data partition" PARTUUID="e9349132-492b-4aa7-91c3-21835e5d4f8f"
You've now got a UUID value that uniquely (hopefully, unless you've been using DD) that defines that disk and no other. If the UUID is not unique use
sudo tune2fs /dev/sda2 -U random
[email protected]:~$ sudo tune2fs /dev/sda2 -U random
tune2fs 1.42.12 (29-Aug-2014)
Then blkid again to see the new value.
[... snipped for clarity ...]
/dev/sda2: UUID="629891a4-1160-489e-8a53-a64c988db6ae" TYPE="ext2" PARTLABEL="Basic data partition" PARTUUID="e9349132-492b-4aa7-91c3-21835e5d4f8f"
So we've now got UUID="629891a4-1160-489e-8a53-a64c988db6ae" as the UUID to work with. If the drive is formatted as NTFS or FAT things are slightly different, but you'll get an ID from the blkid command that you can use.
We add a line to /etc/fstab (use sudo nano to edit that)
UUID=629891a4-1160-489e-8a53-a64c988db6ae /USBdrive     ext4    defaults,noatime       0 1
Save that. Create the mount point
sudo mkdir /USBdrive
then mount it
sudo mount -a
Because it's in fstab it will automount next time you boot.
This is a doctor free zone.
cacophony555
Thu May 07, 2015 3:13 am
I did try using the UUID by adding this to /etc/fstab, but it didn't make a difference:
UUID=dad3727d-6b29-4f64-b7be-abacc0c90a23 /usbdrive auto defaults,noatime 0 1
As before, doing a "sudo mount -a" works, but following reboot the drive is not mounted.
Perhaps the USB devices aren't even being recognized until after the fstab file is read? Maybe I should try autofs instead?
Thu May 07, 2015 6:02 am
The UUID thing is handy if you may have other storage devices connected as it uniquely identifies the device no matter what /dev/sdX name it is given. However, that is not your problem.
What I suspect is happening is that your drive has not had time to initialise properly before the filesystems are mounted. There is a parameter that you can add to cmdline.txt to make the Pi wait a short time before booting to allow the disk(s) to spin-up.
Try adding bootdelay=5 to the line in cmdline.txt. It can go anywhere in the line, but everything must be on one line still.
If that doesn't work, try changing 5 to 10.
cacophony555
Thu May 07, 2015 7:23 am
That's a great suggestion rpdom, thanks for the response. I'll give that a try.
Thu May 07, 2015 10:59 am
rpdom wrote:The UUID thing is handy if you may have other storage devices connected as it uniquely identifies the device no matter what /dev/sdX name it is given. However, that is not your problem.
It's an excellent thing when you accidentally leave a USB stick inserted when you reboot and the hard drive appears as /dev/sdb rather than /dev/sda.
rootdelay=5 should fix the mount at boot problem.
Moksu
Thu May 07, 2015 7:56 pm
Hey,
I just registered this forums to say i have had the same problem than the OP.
But when i saw your respond, where would i need to insert the rootdelay=5 you talked about? (my driver is formated to ntfs-3g tho)
cacophony555
Fri May 08, 2015 5:28 pm
Hey,
It looks like it's here: /boot/cmdline.txt
And the line is bootdelay=5, not rootdelay=5
I'm about to try it...
Fri May 08, 2015 5:41 pm
Not on my system it isn't
dwc_otg.lpm_enable=0 console=tty1 root=UUID=296e7e22-8bb1-4970-8dfd-c24fd4f03346 rootfstype=ext4 elevator=deadline rootwait rootdelay=5
that system has the root fs on a USB HDD formatted as ext4.
cacophony555
Fri May 08, 2015 5:47 pm
Ahh, sorry, didn't notice that you were referring to a slightly different mechanism. Did I get the file location correct?
Fri May 08, 2015 5:48 pm
Actually either rootdelay or bootdelay should work. They have a similar overall effect. rootdelay is specific to waiting for the root device to be ready, while bootdelay is more general.
Yes, /boot/cmdline.txt is correct.
cacophony555
Fri May 08, 2015 7:17 pm
So I initially tried bootdelay=10 and it didn't work. I changed it to rootdelay=10 and it worked.
Thanks again for the help.
zatz
Wed May 20, 2015 5:57 am
Thanks to everyone who has contributed to this thread.
Like cacophony555 I had to use rootdelay to get this to work.
