meikewaldmann
Unload smsc95xx
Wed Jul 11, 2012 7:36 pm
I have some trouble with the smsc95xx when I'm using a 3G modem on USB.
Because I don't need ethernet I thought best way would be to deactivate this module. But it is impossible to unload it with
  • modprobe -r smsc95xx
Therefore my question is:
Is it possible to deactivate the kernelmodul smsc95xx without recompiling the kernel?
Best regards
Meike
secretagent
Re: Unload smsc95xx
Thu Jul 12, 2012 12:13 am
You can try this to disable it:
echo 1-1.1:1.0 > /sys/bus/usb/drivers/smsc95xx/unbind
and to enable it back:
echo 1-1.1:1.0 > /sys/bus/usb/drivers/smsc95xx/bind
meikewaldmann
Re: Unload smsc95xx
Thu Jul 12, 2012 9:07 am
Hello secretagent,
thanks for your help. I think there is a bug in the smsc95xx modul in Debian.
With Raspbian I have no more problems.
I'm looking forward to a bugfree debian. But until that happens I will use Raspbian.
Best regards
Meike
itimpi
Re: Unload smsc95xx
Thu Jul 12, 2012 9:35 am
Isn't that the module that drives the SD card? If so removing it is likely to cause severe problems.
secretagent
Re: Unload smsc95xx
Thu Jul 12, 2012 11:28 am
itimpi wrote:Isn't that the module that drives the SD card? If so removing it is likely to cause severe problems.
No, it's the network driver.
tekmanro
Re: Unload smsc95xx
Sat Aug 25, 2012 5:36 pm
I'm getting an error message when running the unbind command:
-bash: /sys/bus/usb/drivers/smsc95xx/unbind: Permission denied
I tried running it with sudo and without with the same result. Any tips?
Thanks!
dom
Re: Unload smsc95xx
Sat Aug 25, 2012 5:54 pm
tekmanro wrote:I'm getting an error message when running the unbind command:
Either:
sudo su
or
sudo sh -c 'echo 1-1.1:1.0 > /sys/bus/usb/drivers/smsc95xx/unbind'
