My Raspi is working as a rooter on my LAN, it basically send the wifi connection through the ethernet card on which my LAN is connected :
<internet> ---- <wifi rooter> ---- <raspi on wlan0> --- <raspi on eth0> --- <LAN ethernet rooter>
It works great.
But when on my LAN with any PC, I can ping and ssh on the raspi through its wlan0 IP, but nothing on its eth0 IP.
How can I fix it ?
Here is my interfaces file :
pi@raspberrypi ~ $ cat /etc/network/interfaces
auto lo
iface lo inet loopback
auto eth0
#iface eth0 inet dhcp
# the internal (wired) network interface
allow-hotplug eth0
iface eth0 inet static
address 192.168.1.99
network 192.168.1.0
netmask 255.255.255.0
broadcast 192.168.1.255
gateway 192.168.1.99
# the external (wifi) interface
wireless-power off
auto wlan0
allow-hotplug wlan0
iface wlan0 inet static
address 192.168.8.99
broadcast 192.168.8.255
gateway 192.168.8.1
dns-nameservers 192.168.8.1
wpa-ssid "XXXXX"
wpa-psk "XXXXX"
wpa-group TKIP CCMP
wpa-key-mgmt WPA-PSKCode: Select all
pi@raspberrypi ~ $ ifconfig
eth0 Link encap:Ethernet HWaddr b8:27:eb:a3:72:9e
inet adr:192.168.1.99 Bcast:192.168.1.255 Masque:255.255.255.0
UP BROADCAST RUNNING MULTICAST MTU:1500 Metric:1
RX packets:4783664 errors:0 dropped:0 overruns:0 frame:0
TX packets:4872147 errors:0 dropped:0 overruns:0 carrier:0
collisions:0 lg file transmission:1000
RX bytes:1230888411 (1.1 GiB) TX bytes:3583716235 (3.3 GiB)
lo Link encap:Boucle locale
inet adr:127.0.0.1 Masque:255.0.0.0
UP LOOPBACK RUNNING MTU:65536 Metric:1
RX packets:179 errors:0 dropped:0 overruns:0 frame:0
TX packets:179 errors:0 dropped:0 overruns:0 carrier:0
collisions:0 lg file transmission:0
RX bytes:17693 (17.2 KiB) TX bytes:17693 (17.2 KiB)
wlan0 Link encap:Ethernet HWaddr 00:13:ef:70:43:25
inet adr:192.168.8.99 Bcast:192.168.8.255 Masque:255.255.255.0
RX packets:663666 errors:0 dropped:336780 overruns:0 frame:0
TX packets:660277 errors:0 dropped:1 overruns:0 carrier:0
RX bytes:508116145 (484.5 MiB) TX bytes:322254911 (307.3 MiB)
