dogmarcopolo
Raspberry Pi 2 audio output problem
Sat Apr 18, 2015 6:30 pm
my raspberry pi 2 is connected to a hdmi tv but i need audio to come out of the audio jack. i used the following command:
amixer cset numid=3 1
but it dosesn't work. if i use the same command 'amixer cset numid=3' the value is back to '0'.
also tried raspi-config, but it kept going back to '0'.
how can i make this change to stick? Thanks.
xoopha
Re: Raspberry Pi 2 audio output problem
Sat Apr 18, 2015 11:28 pm
Do you have the line
 hdmi_ignore_edid_audio=1
in /boot/config.txt?
Sun Apr 19, 2015 7:46 am
Take everything out of /boot/config.txt (using the NOOBS recovery system editor) by prefixing every line with a #.
The only line you should leave is
gpu_mem=128
Reboot and test your audio.
If it still fails add
gpu_mem=128
hdmi_drive=2
Reboot and test your audio again.
If it still fails try
gpu_mem=128
This is a doctor free zone.
