USBIP package not working in "Raspbian GNU/Linux 7 (wheezy)"
Posted: Sat Apr 18, 2015 2:04 am
by guruqu
I'm trying to use usbip package on raspberry pi2 with "Raspbian GNU/Linux 7 (wheezy)".
I'm following following steps to install and load the package.
apt-get install usbip
modprobe usbip_core
modprobe usbip_host
usbipd -D
After this I'm trying to bind my Logitech USB receiver to give it a test.
At the time, my "lsusb" gives the following.
[email protected]:/home/pi# lsusb
Bus 001 Device 002: ID 0424:9514 Standard Microsystems Corp.
Bus 001 Device 004: ID 046d:c52b Logitech, Inc. Unifying Receiver
Bus 001 Device 005: ID 0bda:8176 Realtek Semiconductor Corp. RTL8188CUS 802.11n WLAN Adapter
Bus 001 Device 006: ID 045e:00db Microsoft Corp. Natural Ergonomic Keyboard 4000 V1.0
And after I'm trying to bind the device. Console gives me following error message.
[email protected]:/home/pi# usbip --debug --log bind --busid=1-1.2
usbip: debug: /build/linux-tools-TqR1ks/linux-tools-3.2.17/drivers/staging/usbip/userspace/src/usbip.c:134:[run_command] running command: `bind'
usbip: debug: /build/linux-tools-TqR1ks/linux-tools-3.2.17/drivers/staging/usbip/userspace/src/usbip_bind.c:162:[unbind_other] 1-1.2:1.0 -> usbhid
usbip: debug: /build/linux-tools-TqR1ks/linux-tools-3.2.17/drivers/staging/usbip/userspace/src/usbip_bind.c:162:[unbind_other] 1-1.2:1.1 -> usbhid
usbip: debug: /build/linux-tools-TqR1ks/linux-tools-3.2.17/drivers/staging/usbip/userspace/src/usbip_bind.c:162:[unbind_other] 1-1.2:1.2 -> usbhid
usbip: debug: /build/linux-tools-TqR1ks/linux-tools-3.2.17/drivers/staging/usbip/userspace/src/utils.c:65:[modify_match_busid] write "add 1-1.2" to /sys/bus/usb/drivers/usbip-host/match_busid
usbip: debug: /build/linux-tools-TqR1ks/linux-tools-3.2.17/drivers/staging/usbip/userspace/src/usbip_bind.c:101:[bind_usbip] bind driver at 1-1.2:1.0 failed
usbip: debug: /build/linux-tools-TqR1ks/linux-tools-3.2.17/drivers/staging/usbip/userspace/src/usbip_bind.c:101:[bind_usbip] bind driver at 1-1.2:1.1 failed
usbip: debug: /build/linux-tools-TqR1ks/linux-tools-3.2.17/drivers/staging/usbip/userspace/src/usbip_bind.c:101:[bind_usbip] bind driver at 1-1.2:1.2 failed
usbip: error: could not bind device to usbip-host
usbip: debug: /build/linux-tools-TqR1ks/linux-tools-3.2.17/drivers/staging/usbip/userspace/src/utils.c:65:[modify_match_busid] write "del 1-1.2" to /sys/bus/usb/drivers/usbip-host/match_busid
Is this happening because the driver is in staging?
From searches I see other people using usbip from default repository on pi without a problem.
Is this problem particular to my version of Rasbian release? Should I fall back to previous version?
Or is compiling it myself the only option?
Many thanks!
Re: USBIP package not working in "Raspbian GNU/Linux 7 (whee
Posted: Thu May 21, 2015 2:35 pm
by lobothefoots
Hi, I'm bumping the thread because I have the same problem.
sudo apt-get install usbip
sudo modprobe usbip-core
sudo modprobe usbip-host
sudo usbipd -D
usbip list -l
Local USB devices
 - busid 1-1 (0424:9514)
         1-1:1.0 -> hub
 - busid 1-1.1 (0424:ec00)
         1-1.1:1.0 -> smsc95xx
 - busid 1-1.3 (0f14:0012)
         1-1.3:1.0 -> cdc_acm
         1-1.3:1.1 -> cdc_acm
 - busid 1-1.4 (090c:1000)
         1-1.4:1.0 -> usb-storage
 - busid 1-1.5 (0f14:000b)
         1-1.5:1.0 -> cdc_acm
         1-1.5:1.1 -> cdc_acm
Next:
usbip --debug --log bind --busid=1-1.4
Result in :
usbip: debug: /build/linux-tools-TqR1ks/linux-tools-3.2.17/drivers/staging/usbip/userspace/src/usbip_bind.c:162:[unbind_other] 1-1.4:1.0 -> usb-storage
usbip: debug: /build/linux-tools-TqR1ks/linux-tools-3.2.17/drivers/staging/usbip/userspace/src/utils.c:56:[modify_match_busid] problem getting match_busid attribute: No such file or directory
I find out that usbip code was moved Inside the kernel in aug 2014
http://thread.gmane.org/gmane.linux.kernel/1763771
Is it normal that debug shows path from build/Tools-TqR1ks instead of tools/usb/usbip ?
Posted: Tue Jul 07, 2015 8:15 am
by JuergenL
Any new conclusions? I have the same problem.
I'm using raspbian wheezy (2015-05-05).
uname -a
Linux raspberrypi 3.18.11+ #781 PREEMPT Tue Apr 21 18:02:18 BST 2015 armv6l GNU/Linux
same error:
sudo usbip --debug bind --busid 1-1.3
usbip: debug: /build/linux-tools-TqR1ks/linux-tools-3.2.17/drivers/staging/usbip/userspace/src/usbip_bind.c:162:[unbind_other] 1-1.3:1.0 -> unknown
usbip: debug: /build/linux-tools-TqR1ks/linux-tools-3.2.17/drivers/staging/usbip/userspace/src/utils.c:65:[modify_match_busid] write "add 1-1.3" to /sys/bus/usb/drivers/usbip-host/match_busid
usbip: debug: /build/linux-tools-TqR1ks/linux-tools-3.2.17/drivers/staging/usbip/userspace/src/usbip_bind.c:101:[bind_usbip] bind driver at 1-1.3:1.0 failed
usbip: debug: /build/linux-tools-TqR1ks/linux-tools-3.2.17/drivers/staging/usbip/userspace/src/utils.c:65:[modify_match_busid] write "del 1-1.3" to /sys/bus/usb/drivers/usbip-host/match_busid
Posted: Sun Jul 12, 2015 10:58 am
by cyquest
# uname -a
Linux 4.0.7+ #802 PREEMPT Wed Jul 8 17:35:23 BST 2015 armv6l GNU/Linu
# usbip --debug bind --busid 1-1.2
usbip: debug: /build/linux-tools-TqR1ks/linux-tools-3.2.17/drivers/staging/usbip/userspace/src/usbip_bind.c:162:[unbind_other] 1-1.2:1.0 -> unknown
Posted: Wed Jul 15, 2015 10:48 pm
by JuergenL
it looks like the new kernel usbip modukes and old debian usbip tools (usbipd and usbip) do not match.
I've compiled the tools and the driver will bind right now.
./usbip --debug bind -b 1-1.5
usbip: debug: usbip.c:141:[run_command] running command: `bind'
usbip: info: bind device on busid 1-1.5: complete
Posted: Thu Jul 16, 2015 6:09 pm
by lobothefoots
Can you tell us how you did compile the tools?
Posted: Fri Nov 27, 2015 11:41 am
by mbadders
Does anyone have information on how to recompile the tools? I'm also having the same problem.
Posted: Mon Jan 11, 2016 8:56 am
by Jarrett
Here's how I got mine working. As much for me future reference as everyone else :)
I'm using a stripped down distro but I expect it'll work for all Wheezy kernels, at least.
(Props to http://shackspace.de/wiki/doku.php?id=berries )
Preamble:
[email protected]:~# uname -a
Linux DietPi 3.6.11+ #1 PREEMPT Fri Jan 4 20:33:41 CET 2013 armv6l GNU/Linux
[email protected]:~# apt-get update && apt-get upgrade -y && apt-get install usbip -y
[email protected]:~# usbipd -D
The missing step:
http://bit.ly/VUPf0k -O usbip.tar.gz
wget http://bit.ly/VUPf0k -O usbip.tar.gz
tar -xzf usbip.tar.gz -C /
reboot
And then:
modprobe usbip-host
modprobe usbip-host
usbip list -l
usbip --debug bind --busid 1-1.5.2
Works for me!
Disclaimers:
Not all of these steps are necessary, probably. But they work and take, like, no time.
There is also a significant chance of breaking your system! Test this on a fresh image with nothing important.
