Canedje
sound not playing at crontab -e
Sat Apr 11, 2015 7:56 pm
I did add a sound to a python file to play.
pygame.mixer.init()
pygame.mixer.music.load("ping.wav")
pygame.mixer.music.play()
while pygame.mixer.music.get_busy() == True:
    continue
This plays fine if I do run by hand:
sudo python tuitlezer.py
If I do run this file by crontab -e the sound is not played.
The crontab command:
*/2 * * * * /usr/bin/python /home/ewh/tuitlezer.py >/dev/null 2>&1
The ">/dev/null" is to prevend sending mail every 2 minutes
Why is thye sound not played by the crontab?
kusti8
Re: sound not playing at crontab -e
Sat Apr 11, 2015 8:46 pm
If your script needs root, did you add it to the root crontab?
Joe Schmoe
Sat Apr 11, 2015 9:07 pm
Or, more to the point, if the command line version requires "sudo", then so also will the crontab version.
Note that this (keeping it in the user 'pi' crontab, but using sudo) is cleaner than the alternative of putting it in the root crontab.
The cleanest solution would be to make the script setuid root, then you wouldn't need sudo at all.
Note 1: I know nothing about Python. I don't know if it is (directly) possible to make a Python script setuid root.
Note 2: I said "directly" in the previous sentence, because there's usually a workaround - a way to get setuid even if the designers of the langauge don't want you to do it. (Shell scripts are a case-in-point)
Canedje
Sat Apr 11, 2015 9:08 pm
kusti8 wrote:If your script needs root, did you add it to the root crontab?
Yes I did
Canedje
Sat Apr 11, 2015 9:13 pm
Yes I did
You triggered me with the root.
The path off the root was not from the root in the python source.
I changed it. Now it workes.
Thanks for the tip
Sat Apr 11, 2015 9:16 pm
You'd have to make python setuid because it's an interpreted language not one that's compiled.
I think the cleanest option is to use sudo in the shebang line
#!/usr/bin/sudo /usr/bin/python
instead of
#!/usr/bin/python
Joe Schmoe
Sat Apr 11, 2015 9:28 pm
Yup, that should work.
