HolyGuacamole
starting a VNC server on boot
Sun Apr 05, 2015 8:45 am
Hello forum,
I 've run into a small problem. I'm trying to access the raspberry via a VNC server. This works. :D
I tried to make the server start when the raspberry pi starts up using this tutorial.
That doesn't. :cry:
What could be the problem?
What steps could I take to check if the server is running?
thanks in advance
AndyD
Re: starting a VNC server on boot
Sun Apr 05, 2015 8:53 am
Yes, that tutorial appears to be incorrect. Specifically the init.d script is set up for the user root, which doesn't have a password on a stock Raspbian install. There is a pull request to make changes to the documentation. The change is to make the init.d script as follows:-
### BEGIN INIT INFO
# Provides: vncboot
# Required-Start: $remote_fs $syslog
# Required-Stop: $remote_fs $syslog
# Default-Start: 2 3 4 5
# Default-Stop: 0 1 6
# Short-Description: Start VNC Server at boot time
# Description: Start VNC Server at boot time.
### END INIT INFO
#! /bin/sh
# /etc/init.d/vncboot
USER=pi
HOME=/home/pi
export USER HOME
case "$1" in
 start)
  echo "Starting VNC Server"
  #Insert your favoured settings for a VNC session
  su - pi -c "/usr/bin/vncserver :0 -geometry 1280x800 -depth 16 -pixelformat rgb565"
 stop)
  echo "Stopping VNC Server"
  /usr/bin/vncserver -kill :0
  echo "Usage: /etc/init.d/vncboot {start|stop}"
  exit 1
esac
exit 0
I haven't tested this, but it looks like it should work.
HolyGuacamole
Sun Apr 05, 2015 2:23 pm
I changed the file and and did the chmod 755 vncboot again.
after that I did update-rc.d vncboot defaults
That said this.
vncboot2 was an attempt to fix it similar to this one.
What does it mean?
[email protected] /etc/init.d $ sudo update-rc.d vncboot defaults
update-rc.d: using dependency based boot sequencing
insserv: script vncboot2: service vncboot already provided!
When I restart it I still can't login using the vnc
xoopha
Sun Apr 05, 2015 4:55 pm
Do you boot into the console or into the desktop? IIRC VNC server can't run unless there's X running.
kusti8
Sun Apr 05, 2015 4:57 pm
xoopha wrote:Do you boot into the console or into the desktop? IIRC VNC server can't run unless there's X running.
What?
Vnc can run if there is no X. Tightvncserver simply starts its own X.
There are 10 types of people: those who understand binary and those who don't.
HolyGuacamole
Sun Apr 05, 2015 7:26 pm
I boot into console.
kusti8
Sun Apr 05, 2015 7:30 pm
A running x is not needed, the problem resides elsewhere.
DirkS
Sun Apr 05, 2015 7:33 pm
The error message seems to be clear enough: somehow there is already a 'vncboot' service active. Disable and remove that, then install the new service.
xoopha
Sun Apr 05, 2015 8:04 pm
Oh right, sorry, I was thinking of x11vnc which actually requires an existing desktop session to connect to.
AndyD
Sun Apr 05, 2015 10:45 pm
AndyD wrote:I haven't tested this, but it looks like it should work.
I will try testing this myself today.
AndyD
Mon Apr 06, 2015 2:51 am
I have run through the process myself (using the init.d script from the pull request as posted above) and it works for me.
HolyGuacamole
Mon Apr 06, 2015 10:02 am
DirkS wrote:The error message seems to be clear enough: somehow there is already a 'vncboot' service active. Disable and remove that, then install the new service.
Ok, this is what i tried.
I removed vncboot2 from etc/init.d/
and then reapplied:
chmod 755 vncboot
then I rebooted:
sudo reboot
When I attempt to connect to the pi using TightVNC Viewer it says this:
Error in TightVNC Viewer: No connection could be made because the target machine actively refused it.
in the shell when i type:
service --status-all
it lists a lot including:
[ ? ] vncboot
so...
AndyD
Mon Apr 06, 2015 11:39 am
Can you tell me what happens if you try the following commands. First
netstat -l  | grep 590
should produce something like
tcp        0      0 *:5900                  *:*                     LISTEN
Next
sudo service vncboot stop
Stopping VNC Server
Killing Xtightvnc process ID 2432
The ID will be different.
Next
sudo service vncboot start
Starting VNC Server
New 'X' desktop is raspberrypi:0
Starting applications specified in /home/pi/.vnc/xstartup
Log file is /home/pi/.vnc/raspberrypi:0.log
Can you post any results that are different than the ones I have shown. Also, make sure that /etc/init.d/vncboot is the one I have posted above, not the one in the Raspberry Pi documentation.
HolyGuacamole
Mon Apr 06, 2015 12:37 pm
the first one does not produce anything
the second...
Stopping VNC Server
Can't find file /home/pi/.vnc/raspberrypi:0.pid
You'll have to kill the Xtightvnc process manually
### BEGIN INIT INFO
# Provides: vncboot
### END INIT INFO
#! /bin/sh
USER=pi
HOME=/home/pi
export USER HOME
case "$1" in
 start)
  su -pi -c "/usr/bin/vncserver :0 -geometry 1280x800 -depth 16 -pixelformat rgb565"
 stop)
  exit 1
esac
exit 0
when I copied this from gedit, I noticed that at the bottom it says
Matlab table width: 8
Is this ok?
AndyD
Mon Apr 06, 2015 12:40 pm
There is a missing space between the dash (-) and the pi. It should be:-
Edit the file then try:-
HolyGuacamole
Mon Apr 06, 2015 12:52 pm
The space was the problem....... a space :cry:
thanks for all the help.
it works now
HolyGuacamole
Thu Apr 09, 2015 8:38 am
I decided my mistake should have some educational value. :lol: :lol:
why does the - pi need a space and the -c not?
can the -c have a space? (e.i. - c)
AndyD
Thu Apr 09, 2015 9:38 am
HolyGuacamole wrote:I decided my mistake should have some educational value. :lol: :lol:
Have a look at the manual page for su, use the following in a terminal:-
man su
The su command takes a number of command line options. In Linux the defacto standard for command line options is to use a dash character for command line options. The dash (-) and (-c) are both command line options to the su command. Additionally the su command be provided with a username on the command line, in our case the user pi. If there is no space between the dash and the pi, the su command will interpret it as a command line option -pi, and will exit with an error.
jimsmith93
Thu Apr 09, 2015 1:16 pm
I could not get the VNC server to successfully start on boot either. Then I tried AndyD's revised script and success!
Thanks :D
AndyD
Thu Apr 09, 2015 1:21 pm
jimsmith93 wrote:I could not get the VNC server to successfully start on boot either. Then I tried AndyD's revised script and success!
Thanks :D
Thanks, but I can't take credit for the changes. They are changes waiting to be merged into the Raspberry Pi documentation as suggested by Github user Balsimir
jimsmith93
Sun Apr 12, 2015 3:44 pm
Then...thank you Balsmir too.
Alomamabobo
Wed Apr 29, 2015 7:43 pm
Thank You :)
jogl
Thu Jan 12, 2017 6:48 pm
Sorry about this, I know that this is an old thread.
Where could I find a copy of the tutorial referred to in the OP's post?
Edit: Found it.
http://elinux.org/RPi_VNC_Server
