Canedje
Unable to show .png from other directory then /var/www
Fri Apr 03, 2015 7:53 pm
I do have two raspberri's connected by a Mount
The mount directory is: /mnt/PI
I did make a subdirectory : rrdtemp
So the total directory will be /mnt/PI/rrdtemp
In shell I can read and approach or copy files from the directory mentioned above to a local dir
I try to show the pictures from this directory on a website.
I'm not able to do so.
I'm using this HTML command
    <img src="/mnt/PI/rrdtemp/tmonthly.png" />n
I also tried:
<img src="../../mnt/PI/rrdtemp/tmonthly.png" />
No result
If I move the directory manually to the local /var/www/rrtemp by shell
and change the HTML code in:
   <img src="/rrdtemp/tmonthly.png" />
The picture is showing
So I can only show pictures from the directory /var/www and lower.
Not from a directory anywhere else
How can I read the pictures straight from the mount or other directory in the html code?
Re: Unable to show .png from other directory then /var/www
Fri Apr 03, 2015 8:21 pm
Links are relative to the DocumentRoot, not the filesystem of the computer,
You can add other locations. Assuming you are using apache you can add an alias statement to the apache config file
Alias /rrdtemp /mnt/PI/rrdtemp
then restart/reload apache and use
Now /mnt/PI/rrdtemp will appear as /rrdtemp on your website.
Canedje
Fri Apr 03, 2015 8:59 pm
Thanks a lot
It worked!
