Canedje
Not able to read ds18b20 temp sensor
Fri Apr 03, 2015 1:33 pm
I do try to read the temp from a ds18b20 sensor.
I installed WiringPi by the way: http://wiringpi.com/download-and-install/
I installed the sensor and tried to read it by the: https://iada.nl/blog/artikel/temperatuu ... spberry-pi
I checked the connection between the sensor and the py several times. There is 3.3V at the sensor
The data is connected to pin 7 of the GPIO (GPIO 4). There is a resistor 0f 4.7KOhm between 3.3V and data pin
If I look in :
ewh@raspberrypi-2 /sys/bus/w1/devices $ ls -l
totaal 0
There are no sensors visible.
Beside this I'm able to switch off and on a LED on GPIO 17. So it looks like the GPIO is working correctly.
cd
What am I doing wrong?
Please advice
B.Goode
Re: Not able to read ds18b20 temp sensor
Fri Apr 03, 2015 1:45 pm
If you are running a recent or updated version of Raspbian, this might be relevant: http://www.raspberrypi.org/forums/viewt ... 28&t=97314
Fri Apr 03, 2015 1:51 pm
Add
dtoverlay=w1-gpio
to /boot/config.txt and reboot.
Canedje
Fri Apr 03, 2015 2:01 pm
DougieLawson wrote:Add
dtoverlay=w1-gpio
Thanks a lot!!!
That was the solution.
I can read the ds18b20 now
I also have the dht22 sensor. Do I need to do something in advance for this sensor?
Fri Apr 03, 2015 2:08 pm
For i2c and spi devices add
dtparam=i2c_arm=on
dtparam=spi=on
Canedje
Fri Apr 03, 2015 2:40 pm
Thanks again
It all workes fine now!
