duzuike
overscan & wifi dongle
Fri Apr 03, 2015 8:11 am
I have a raspberry pi 2 model B with the latest Debian OS.
The usb wifi dongle has been worked perfectly.
But if I disabled the overscan option in config.txt , the wifi dongle can't connect.
Apr  3 15:36:10 raspberrypi wpa_supplicant[1982]: wlan0: SME: Trying to authenticate with e0:30:05:af:43:2c (SSID='ChinaNet-wwg' freq=2462 MHz)
Apr  3 15:36:10 raspberrypi kernel: [  159.104776] wlan0: authenticate with e0:30:05:af:43:2c
Apr  3 15:36:10 raspberrypi kernel: [  159.463306] wlan0: send auth to e0:30:05:af:43:2c (try 1/3)
Apr  3 15:36:10 raspberrypi kernel: [  159.670743] wlan0: send auth to e0:30:05:af:43:2c (try 2/3)
Apr  3 15:36:11 raspberrypi kernel: [  159.880735] wlan0: send auth to e0:30:05:af:43:2c (try 3/3)
Apr  3 15:36:11 raspberrypi kernel: [  160.090748] wlan0: authentication with e0:30:05:af:43:2c timed out
AndyD
Re: overscan & wifi dongle
Fri Apr 03, 2015 8:55 am
Are you 100% sure? The overscan setting would appear to be unrelated to a usb wifi dongle. Can you reproduce it, or was it just that you edited config.txt, rebooted and found your wifi would no longer connect?
duzuike
Fri Apr 03, 2015 9:39 am
AndyD wrote:Are you 100% sure? The overscan setting would appear to be unrelated to a usb wifi dongle. Can you reproduce it, or was it just that you edited config.txt, rebooted and found your wifi would no longer connect?
I'm sure, and I can reproduce it.
After change the overscan option (using vim or raspi-config), I tried rebooting and power off (remove the power plug).
If overscan is disabled , the wifi dongle can't connect. If overscan is enabled, after rebooting, the wifi dongle works perfectly.
AndyD
Fri Apr 03, 2015 9:44 am
duzuike wrote:I'm sure, and I can reproduce it...
That is very interesting. I must admit I have some intermittent wifi issues with my Pi2, but I had assumed it was an issue with my power supply.
eriktheitalian
Fri Apr 03, 2015 10:02 am
Interesting and important.
Are u tried newer firmware ? If possible pls try and release result.
I cant using enough English language. My writings can be wrong grammer.$
"in micro$oft we not trust"
Fri Apr 03, 2015 11:24 am
Are you sure you've got the right SSID/password for the AP at e0:30:05:af:43:2c?
Note: Having anything remotely humorous in your signature is completely banned on this forum. Wear a tinfoil hat and you'll get a ban.
This is a doctor free zone.
