ddevejian
Trouble with 1wire
Wed Apr 01, 2015 12:14 am
I am having difficulty with the 1wire driver in raspberian. I am trying to set up a thermal sensor with a DS18B20, but I am unable to see anything.
When I try to list the devices in the fs, this is what I see.
pi@raspberrypi /sys/bus/w1/devices $ ls
00-400000000000  00-800000000000  w1_bus_master1
The 00-400000000000 and 00-800000000000 will change from time to time, (always a 00-) but their contents do not appear similar to what I am expecting:
00-200000000000  w1_bus_master1
pi@raspberrypi /sys/bus/w1/devices $ cd 00-200000000000
pi@raspberrypi /sys/bus/w1/devices/00-200000000000 $ ls
driver  id  name  rw  subsystem  uevent
This is what I am seeing in messages related to the one wire driver:
Apr  1 00:02:25 raspberrypi kernel: [    4.112221] w1-gpio onewire@0: gpio pin 4    , external pullup pin -1, parasitic power 0
Apr  1 00:02:25 raspberrypi kernel: [    6.083494] w1_master_driver w1_bus_maste    r1: w1_search: max_slave_count 64 reached, will continue next search.
Apr  1 00:03:18 raspberrypi kernel: [   53.479054] w1_master_driver w1_bus_maste    r1: Family 0 for 00.800000000000.8c is not registered.
Apr  1 00:04:18 raspberrypi kernel: [  112.790023] w1_master_driver w1_bus_maste    r1: Family 0 for 00.400000000000.46 is not registered.
Apr  1 00:05:05 raspberrypi kernel: [  160.150673] w1_master_driver w1_bus_maste    r1: Family 0 for 00.c00000000000.ca is not registered.
Apr  1 00:06:16 raspberrypi kernel: [  231.411904] w1_master_driver w1_bus_maste    r1: Family 0 for 00.200000000000.23 is not registered.
Apr  1 00:07:16 raspberrypi kernel: [  290.722895] w1_master_driver w1_bus_maste    r1: Family 0 for 00.a00000000000.af is not registered.
Apr  1 00:07:51 raspberrypi kernel: [  326.136136] w1_master_driver w1_bus_maste    r1: Family 0 for 00.600000000000.65 is not registered.
Apr  1 00:08:28 raspberrypi kernel: [  363.464118] w1_master_driver w1_bus_maste    r1: Family 0 for 00.e00000000000.e9 is not registered.
This behavior does not change even if I disconnect everything from the GPIO.
I am loading w1-gpio and w1-therm at boot via /etc/modules
The following line is in my config.txt:
# Enable 1wire
dtoverlay=w1-gpio,gpiopin=4
I am running 3.18.10:
pi@raspberrypi / $ uname -a
Linux raspberrypi 3.18.10-v7+ #774 SMP PREEMPT Wed Mar 25 14:10:30 GMT 2015 armv7l GNU/Linux
pi@raspberrypi / $
Any suggestions or further troubleshooting would be greatly welcome.
ddevejian
Re: Trouble with 1wire
Wed Apr 01, 2015 1:08 pm
I forgot to mention, its a PI 2.
joan
Wed Apr 01, 2015 1:12 pm
Should you be loading the modules in /etc/modules if you are using device tree?
That said, if you get varying results that suggests a loose or incorrect connection.
How have you connected the sensor? I.e. what connections have you made between the sensor and the Pi.
ddevejian
Wed Apr 01, 2015 1:30 pm
There was no difference in behavior when I loaded the modules via modprobe. I stuck them in /etc/modules to save myself from typing that manually each time I booted.
I do not think this is a loose connection, because, as I mentioned above, this behavior happens even with nothing connected to the GPIO. (At which point there is only the power supply and an ethernet connection.)
Im using a ribbon cable from the GPIO to a breadboard, from which I connect 3V3 to the positive power rail, GND to the negative, the sensor GND directly to the GND rail, sensor Vdd to the positive power rail and sensor DQ to a 4k7 ohm resistor that connects to the positive rail and a second connection from sensor DQ to pin 4. Pretty much exactly the layout seen here: http://www.reuk.co.uk/DS18B20-Temperatu ... rry-Pi.htm
Ive tried changing the data pin, I used 18 with the same behavior.
My guess it the issue is here:
I have either one or no devices connected, I cannot understand why it thinks the max_slave_count of 64 is reached.
joan
Wed Apr 01, 2015 2:00 pm
You should not be loading the modules in /etc/modules (or manually) if you are using device tree. I don't know what effect trying to load the modules multiple times will have.
ddevejian
Wed Apr 01, 2015 11:43 pm
I had seen a number of websites that described doing both, setting the dtoverlay in config.txt and issuing the modprobe commands. Nevertheless, having now readup on what device tree is and does, I would agree that issuing modprobe (or including it in /etc/modules) is redundant for w1-gpio if you are using the dtoverlay in config.txt.
There does not appear to be an overlay that includes w1-therm, so that may still need to be loaded manually, however, Ill worry about that later, right now the problem seems to be with w1-gpio.
Removing both w1-gpio and w1-therm from /etc/modules does not solve the problem. I still see the errors in /var/log/messages about maximum_slave_count reached as well as the Family 0 for 00-XX000000000 not registered. And the spurious device ids in /sys/bus/w1/devices.
Since these errors occur without my circuits attached to the pi, Im fairly certain my wiring has nothing to do with this.
Where can I go from here?
ddevejian
Thu Apr 02, 2015 2:11 am
All right, its working.
I found a couple of comments in other forums that suggested that the "Family 0 for 00-XX00000000000.YY is not registered" message is not an error, but typical behavior for the 1wire driver when nothing is attached.
Based off of that, I reattached my circuit and started to double check everything. Looking at the datasheet for the DS18B20, the input voltage is 3.0 to 5.5. Thinking that perhaps the 3v3 pin wasnt delivering sufficient voltage for whatever reason, I tried the 5v0 on pin 2. Still no love. However, when I changed the ground pin from pin 9 to pin 6, low and behold it started working. (Ive since moved back to the 3v3 on pin 1 for power and it continued to work.) For the moment Im going to assume there is a break in my ribbon cable or the T-Connector I used to connect the GPIO to the breadboard. Digging into exactly whats happening there will be a labor for another day.
I appreciate your help, Joan.
DMike92
Sat May 09, 2015 11:08 am
Thank a lot for your auto-reply ddevejian. I'm having exactly the same trouble wich drives me crazy because it was working nicely on my Pi B+ until a software change (apt-get xxx + apt-get upgrade).
I will try what you said and come back.
Le savoir ne vaut que quand il est partagé (c'est pas de moi mais j'adhère).
pluggy
Sat May 09, 2015 12:12 pm
Its a problem with the 3.18 kernels and device tree not working with the old way of doing things. Unfortunately the old way of doing things stick around a long time on the internet. I've avoided upgrading my Pis doing one wire stuff because of the changes that need to be made. It can be done, but I forget where I've seen the solution.
aewdummy
Wed May 20, 2015 2:41 pm
Hi
Can I add my two pennyworth to this discussion
I have an add on board attached to a Pi 1 model b. NEARLY ALL the gpios are in use. It has worked just fine to 12 months.
If I attach the board to a Pi 2, the I get the following ( as others get too ) from dmesg, the 1 wire stops working and I don't get the expected subdirectories in /sys/bus/w1/devices
w1-gpio onewire@0: gpio pin 4, external pullup pin 5, parasitic power 0
w1_add_master_device: set_pullup requires write_byte or touch_bit, disabling
w1_master_driver w1_bus_master1: w1_search: max_slave_count 64 reached, will continue next search.
I have nothing on pin 5
Note the "w1_search: max_slave_count 64 reached" which seems to be my problem
If I just jumper gpio4, power and earth between the Pi 2 and the board THE 1WIRE WORKS PROPERLY and the "w1_search: max_slave_count 64 reached" message is not present
I have tried to selectively jumper other gpio pins, but I can't locate the problem.
Is there a gpio pin ( other than 4 ) that is involved in 1 wire?
Thanks for any insight you can give me
A
forzalaquila
Mon Nov 16, 2015 2:30 pm
I my friend
For anybody think that GPIO4 can be damaged and want to try to change to another GPIO pin.
After a lots of try i have made this and it has worked:
1) use a pretty old kernel version without device tree .I'm using 3.12.36 and you can download from sudo rpi-update f74b92120e0d469fc5c2dc85b2b5718d877e1cbb
2) edit, from root, /boot/cmdline.txt end put at the ending of line this bcm2708.w1_gpio_pin=18 (18 is the GPIO number that you want use.The file must be only 1 line)
3) reboot and enjoi
ciao
cesare
Mon Nov 16, 2015 7:06 pm
Why not use the support in the device tree kernels?
dtoverlay=w1-gpio,gpiopin=nn
dtoverlay=w1-gpio,pullup=on,gpiopin=nn
dtoverlay=w1-gpio-pullup,gpiopin=nn,extpullup=nn
dtoverlay=w1-gpio-pullup,pullup=on,gpiopin=nn,extpullup=nn
Docs are in /boot/overlays/README.
on4ami
Wed Nov 15, 2017 10:43 am
I'm also having.
After a couple of day my 4 DS18B20 report a different ID starting 00-.
My pullup resistor is 4k7 all connected to GPIO pin 4.
do i still need :
command:
sudo modprobe w1-gpio pullup=1
Or don't use an external resistor.
KR
Pat
pcmanbob
Wed Nov 15, 2017 1:33 pm
You don't need to use any modprobe commands now if you are using raspbian stretch.
you just need to enable 1-wire either via raspi-config or by adding dtoverlay=w1-gpio to /boot/config.txt. then reboot.
With your sensors connected to the default pin 7 or gpio 4 if you prefer, with an external 4.7k resistor.
if you do
cd /sys/bus/w1/devices
ls
you should see your sensor ID's listed.
braveness23
Mon Dec 11, 2017 1:22 am
pcmanbob, this is great and a big help! I've changed my config as you described and I now see my devices in /sys/bus/w1/devices/
pi@hometemp:~ $ ls /sys/bus/w1/devices/
3b-000000183532  3b-000000186e31  3b-000000186e4a  w1_bus_master1
But I do not have w1_slave as a sub-directory for these devices any more. How do I actually read the temperature from my devices now?
I am running raspbian stretch on a Pi 2 Here is my hardware configuration:
https://github.com/braveness23/Hometemp ... ers_bb.png
if you do
ls
pcmanbob
Mon Dec 11, 2017 4:02 pm
So now you have your devices showing up, you need to cd in to the device directory
cd /sys/bus/w1/devices/3b-000000183532
then as a test do
cat w1_slave
which will show the raw temperature reading output by the sensor the t=xxxxx being the temperature.
this python code will read one temp sensor for you and return the temp in C
#!/usr/bin/python
import time
def read_temp_raw():
    device_file = "/sys/bus/w1/devices/enter sensor ID here/w1_slave"
    print device_file
    f = open(device_file, "r")
    lines = f.readlines()
    f.close()
    return lines
def read_temp():
    lines = read_temp_raw()
    while lines[0].strip()[-3:] != "YES":
        time.sleep(0.2)
    equals_pos = lines[1].find("t=")
    if equals_pos != -1:
        temp_string = lines[1][equals_pos+2:]
        temp_c = float(temp_string) / 1000.0
        return temp_c
print "Start "
temperature = (read_temp())
print temperature
DMike92
Tue Jan 02, 2018 11:28 pm
For those still having trouble, make sure that /etc/modules contains both
w1-gpio
w1_therm
Note that the last one has an underscore (I tried with w1-therm and had the "64..." message in dmesg)
lsmod should read 3 important lines if correct :
Module         Size  Used by
w1_gpio        4534  0
w1_therm       4475  0
wire          31801  2 w1_gpio,w1_therm
(size values may differ)
Check that the last one uses the 2 others
This configuration works for me for non parasitic probes (3 wires and a 4.7K between VCC and Data on pin 4)
So my /boot/config.txt contains at the end :
dtoverlay=w1-gpio
# NOTE : After playing with those and putting all back in place, it does not work anymore! dmesg is showing:
After having done more testing, it appears that the probes disappears without doing anything. I suspect a hardware issue.
danclark
Tue Apr 09, 2019 1:09 pm
OK, I had the same issues here for hours and found this post by JumpNow Technologies...
https://jumpnowtek.com/rpi/Using-DS18B2 ... ry-Pi.html
I basically ended up using the Parasitic Powering wiring setup where both the +ve and -ve (red/black) wires are wired to GND.
Then you just wire the data wire (yellow) to the input with a 4.7k resistor back to 3.3V.
It worked immediately!
pi@raspberrypi:~ $ ls /sys/bus/w1/devices/
28-00000a00ebc0  28-031701881eff  w1_bus_master1
