rappib
noobs setup says 0mb available on micro-sd
Tue Mar 31, 2015 10:28 pm
Hello everyone,
Since the search took like 80% of my searchwords out of the search i couldnt search for it, when i get the setup of installing noobs and the os' i want to install raspbian and openelec but my sd supposely has no space left, i checked on my windows 8 and it does have lots of space left. It is not the first start, i wanted to setup my pi fresh after having had it working with raspbian only. It's a model b+ and noobs 1.3.9..
I did try to resize the sd with parted but got the error that it was mounted and when i tried
Umount /mnt
It said nothing
And when i did
Umount /settings
It said invalid argument
Pls help me, ask for further info
Delipunch
Re: noobs setup says 0mb available on micro-sd
Tue Mar 31, 2015 11:55 pm
Have you tried https://www.sdcard.org/downloads/formatter_4/
If not,
1) Wipe card with tool provided;
2) Unzip NOOBs to the sd card; and
3) It should now work.
rappib
Wed Apr 01, 2015 4:27 pm
I did that before, now it does work, seems my own first copy I took from the start-up micro-sd i bought is broken...but there is still one other problem, where can I find a version of noobs including open elec and raspbian?
so i guess it was the bad copy of the sd I saved on my pc and copied it back onto the micro-sd
Best Wishes
