Jwoolington
get-apt upgrade failing. Can't install any packages
Tue Mar 31, 2015 7:32 pm
Tried running the following:
get-apt update
get-apt upgrade -y
Upgrade fails with "size mismatch" errors.
Can't install any packages, that also fails.
Any suggestions?
CaptSunset
Re: get-apt upgrade failing. Can't install any packages
Wed Apr 01, 2015 1:45 am
Hi J-
Try apt-get , it should work much better than get-apt
No worries!
ddevejian
Wed Apr 01, 2015 1:51 am
Possibly a proxy issue. Are you running this in a corporate environment with some sort of web filtering?
I was having a similar issue at my office, turned out the file gets were being blocked by Websense. Interestingly, the regular debian distribution sites are permitted.
Jwoolington
Wed Apr 01, 2015 12:09 pm
I miss-typed. I am using apt-get. Lol!
But yes, it is in a corporate environment and there is websense being used. Any way around this? Should I allow the source list address through websense?
Wed Apr 01, 2015 12:21 pm
Have you configured the system wide or apt-get proxy settings?
ddevejian
Wed Apr 01, 2015 12:43 pm
Yeah, if it doesnt require forms in triplicate and sign-off by executive management, whitelisting your source address is probably easiest. That or making an exception for the raspberry pi distribution archives.
If its websense, I dont think changing the proxy configuration on the pi will help, websense usually doesnt rely on a proxy but monitors network connectivity directly, either through a firewall or a monitor port.
Jwoolington
Wed Apr 01, 2015 12:58 pm
Thanks. I'll try that. I have access to all that. This is my first time using the pi so I was really unsure what was causing the problem. I thought maybe a corrupt SD card.
Jwoolington
Wed Apr 01, 2015 1:08 pm
I am now running into a new error message that I have researched and tried multiple fixes, but can't seem to solve the problem.
W: GPG error: http://ftp.us.debian.org wheezy Release: The following signatures couldn't be verified because the public key is not available: NO_PUBKEY 8B48AD6246925553 NO_PUBKEY 6FB2A1C265FFB764
DirkS
Wed Apr 01, 2015 1:10 pm
Which distro do you use? Raspbian, Debian or any other?
If it's Raspbian did you make any changes to /etc/apt/sources.list?
Jwoolington
Wed Apr 01, 2015 1:22 pm
I made a change to the source list to try and solve the problem. It now reads: deb http://ftp.us.debian.org/debian/ wheezy main contrib non-free
Jwoolington
Wed Apr 01, 2015 1:27 pm
Found the problem.
apt-get install debian-archive-keyring
