B+ Power Supply Question
Posted: Sun Mar 29, 2015 11:22 pm
by BeeKeeper2014
I'm working on a project to turn one of my Honey Bee Hives into a smart Hive with the B+. Question I have is will the B+ run fine on a 12V @ 1.2 AMPs?
I'll be running the PI, 12V Fan, 4-5 Sensors, camera and WiFi.
I can drop the power supply down to 6V @ 1.2 AMPS if anyone thinks that will be enough power.
Re: B+ Power Supply Question
Posted: Mon Mar 30, 2015 12:12 am
by xoopha
The B+ (or any other Pi for the matter) works on 5V. Feed it anything bigger and it will wave you goodbye.
Posted: Mon Mar 30, 2015 12:13 am
by BeeKeeper2014
xoopha wrote:The B+ (or any other Pi for the matter) works on 5V. Feed it anything bigger and it will wave you goodbye.
So 6V is out of question also?
Posted: Mon Mar 30, 2015 12:19 am
by xoopha
Yes.
Posted: Mon Mar 30, 2015 12:20 am
by BeeKeeper2014
Well crap. Guess I need to find a way to step it down to 5V then...
Posted: Mon Mar 30, 2015 12:54 am
by klricks
BeeKeeper2014 wrote:Well crap. Guess I need to find a way to step it down to 5V then...
Step down from 12V to 5V is easy and cheap. Get a car USB charger and use that. http://www.ebay.com/itm/Dual-USB-2-Port ... 19eaeddfd0
You can attach wires to it directly or buy a DIY wire-in 12V socket at an auto-parts store etc.
Posted: Mon Mar 30, 2015 12:56 am
by BeeKeeper2014
That's a good idea! Thanks.
Posted: Mon Mar 30, 2015 12:38 pm
by drgeoff
Do not try to use the Poundland item which has 2 cigarette lighter sockets and a USB 5 volt output. Its electronics consists of nothing more than a solitary 78L05 type regulator in a TO-92 package. Plastic package, no heatsink of any kind, dropping 9 volts. It won't power or charge anything requiring more than a miserly current before overheating and shutting down.
