dhbarr
Re: NOOBS SD card partitions not detected in Linux
Sun Sep 20, 2015 8:36 pm
Just chiming in to echo that the offset method worked for me, when nothing else would:
$ sudo fdisk -l /dev/mmcblk0
Disk /dev/mmcblk0: 15.7 GB, 15719727104 bytes
4 heads, 16 sectors/track, 479728 cylinders, total 30702592 sectors
Units = sectors of 1 * 512 = 512 bytes
Sector size (logical/physical): 512 bytes / 512 bytes
I/O size (minimum/optimal): 512 bytes / 512 bytes
Disk identifier: 0x000bbe14
        Device Boot      Start         End      Blocks   Id  System
/dev/mmcblk0p1            2048      242187      120070    e  W95 FAT16 (LBA)
/dev/mmcblk0p2          245760    30637055    15195648   85  Linux extended
/dev/mmcblk0p3        30637056    30702591       32768   83  Linux
/dev/mmcblk0p5          253952      581631      163840    c  W95 FAT32 (LBA)
/dev/mmcblk0p6          589824    30636031    15023104   83  Linux
$ sudo mount /dev/mmcblk0 /media/dhbarr/mmc -o offset=$((589824*512))
$ mount | grep mmc
/dev/mmcblk0 on /media/dhbarr/mmc type ext4 (rw)
ayler31
Wed Mar 09, 2016 1:44 am
I had the same problem, and got a solution.
command "partprobe /dev/mmcblk0" did the trick.
lgenzelis
Tue May 24, 2016 5:52 am
ayler31 wrote:command "partprobe /dev/mmcblk0"
The simplest and most effective solution. Thank you!
