Josephus
module spi-dev
Sun Mar 22, 2015 10:09 am
During start-up, I receive the message :
fatal : module spi-dev not found
Afterwords the Pi1 will stop !!!!
:roll: :roll: :roll:
joan
Re: module spi-dev
Sun Mar 22, 2015 10:16 am
Which operating system? Where did you get it? Have you made changes?
Re: module spi-dev
Sun Mar 22, 2015 10:55 am
spi-dev doesn't exist in the 3.18 kernel.
modprobe spi-bcm2708
Failing to load an optional kernel module is probably not the reason your RPi stopped.
Josephus
Re: module spi-dev
Sun Mar 22, 2015 11:15 am
DougieLawson wrote:spi-dev doesn't exist in the 3.18 kernel.
I use Rasbian on the Pi1 with the Dexter GoPiGo. It functions perfect during half a year.(Terminal, Python and scratch).
After a apt-get upgrade, the system stopped. Since that event I got this message on spi-dev.
I do not know how to proceed .......
DirkS
Re: module spi-dev
Sun Mar 22, 2015 11:39 am
Josephus wrote:I do not know how to proceed .......
If the upgrade installed the latest kernel 3.18 (you can check this with 'uname -r') then you probably have to add
dtparam=spi
to /boot/config.txt
But maybe it's best to post your problem on the Dexter forum (http://www.dexterindustries.com/forum/)
Re: module spi-dev
Sun Mar 22, 2015 11:45 am
1. Buy a new 8GB SDCard
2. Buy a USB SDCard reader (costs £1 in Poundland)
3. Build a new version of Raspbian on the new card
4. Boot from the new card
5. Insert the "broken" card in the USB reader
6. Mount the /dev/sda2 (non-NOOBS) or /dev/sda6 (NOOBS) filesystem
7. Inspect the logs and stuff in /var/log to see if you can determine the cause of the failure
Romey-Rome
Re: module spi-dev
Fri Apr 17, 2015 1:06 am
Hello -
So how do you permanently increase the buffer size with spi-bcm2708? I don't see it having any parameters.
joan
Re: module spi-dev
Fri Apr 17, 2015 8:09 am
Romey-Rome wrote:Hello -
It's probably best to create a new post for a new question. It gets its own title so people know to look at the post if they are interested or can help.
That said, I didn't realise the SPI module had a configurable buffer. The user supplies a buffer of an appropriate size for the data to be read/written.
