PI2B installation - SD-card problem
Posted: Tue Mar 17, 2015 5:46 pm
this is my first post. Be patient with me! Thank You
I got my first card "Raspberry Pi Model B" and I tried to boot it with a new SD-card, but it did'nt work.
Consider that I read the article STICKY BOOT PROBLEM http://www.raspberrypi.org/forums/viewt ... 28&t=58151(also for PI2B) and that my SD-card (Kingston SDC10 / 16GB) is on the list of the Working ones.
It happened that my PI2B did'nt booted properly and in the end I found that the content of SD-card was deleted (the SD-crad was corrupted).
In particular:
- I connected my new PI2B to a Samsung TV (HDMI), to a mouse and to a keyboard (USB) and then to the power supply,
- suddenly the red led turned on, and also the green one (after a while it started blinking),
- on the monitor it appeared the warning: unsupported mode,
- then for a moment I saw a white screen (disturbed) with the raspberry icon ,
- I noticed a beginning of activity,
- then the monitor was turned off with the message "unsupported mode" and also the green LED went off,
- I unplugged the power,
- I removed the SD-card and checked on a PC that its contents was deleted. Now it contains only the file noobs.conf
[General]
display_mode = 0
keyboard_layout = gb
language = enI ran again the sequence of actions, after reformatted the SD-card and having flashed it with NOOBS_v1_4_0 and got the same result: the PI2B did'nt boot and SD-card resulted corrupt again!
What's up?
Who changed the name of SD-card, deleted its content and wrote file noobs.conf?
Claudio
