smbaker
Python GPIO does not work on Raspberry Pi 2
Sun Mar 15, 2015 5:17 am
I'm using the latest downloadable Raspbian image. Rpi.GPIO 0.5.11 is installed. I've also tried building Rpi.GPIO from mercurial checkout.
gpio from the command line works fine:
gpio -g mode 27 out
gpio -g write 27 1
gpio from python does not:
import RPi.GPIO as IO
import time
IO.setmode(IO.BCM)
IO.setup(27, IO.OUT)
IO.output(27, IO.HIGH)
try:
    while True:
       time.sleep(1)
finally:
    IO.cleanup()
The pin never goes high with the python code. Am I doing something wrong? Similar code works just fine on my B+ boards.
Thanks,
Scott
Cole1717
Re: Python GPIO does not work on Raspberry Pi 2
Mon Mar 16, 2015 10:46 pm
I am having the exact same problem and I can't find anything online addressing it. I might try reinstalling Raspbian if no one finds a solution.
slmaws
Tue Mar 17, 2015 12:52 am
Does it change to output mode? You can check it with
gpio readall
See my Raspberry Pi tips on http://rpitips.com
Cole1717
Mon Mar 23, 2015 10:36 pm
slmaws wrote:Does it change to output mode? You can check it with
gpio readall
I tried this, but readall isn't working. Any idea why? I can't figure it out. It is version 0.5.11.
import RPi.GPIO as gpio
gpio readall
throws a syntax error.
Mon Mar 23, 2015 10:52 pm
gpio readall
You've mixed things up nicely. RPi.GPIO is a python library. gpio is a command line program (written in C).
Open an LXTerminal window & type
gpio readall
then press [ENTER]
joan
Mon Mar 23, 2015 11:00 pm
Are you sure? Which parts? http://abyz.co.uk/rpi/pigpio/python.html
Cole1717
Tue Mar 24, 2015 11:54 am
That explains it. I don't know why I didn't realize that's what slmaws meant. I'll let you know what it says when I get home from work. I still haven't been able to get python to set a pin high yet.
Tue Mar 24, 2015 12:48 pm
Cole1717 wrote:I still haven't been able to get python to set a pin high yet.
#!/usr/bin/sudo /usr/bin/python
from time import sleep
g.setmode(g.BCM) # broadcom numbering
g.setup(17, g.OUT) # GPIO17 == physical pin#11
while True:
  g.output(17, g.HIGH)
  sleep(0.5)
  g.output(17, g.LOW)
  sleep(0.5)
save that as /home/pi/b.py
Open an LXterminal window
chmod 755 b.py # press [ENTER]
./b.py # press [ENTER] to run it
[CTRL]+[C] to make it stop.
craigo2015
Wed Mar 25, 2015 8:02 pm
Couldnt get Python GPIO to work on my Pi 2 either.
I can output to GPIO pins by echoing values to /sys/class/gpio and using the wiringpi gpio utility but not with rpi.GPIO
I will check whether gpio readall shows rpi.GPIO setting the output correctly at the weekend.
mahjongg
Wed Mar 25, 2015 11:57 pm
If rpi.GPIO hasn't had an update since the B2 came out then that explains it, all libraries that drive GPIO's must check whether they run on a pre-2B or a 2B or later (on a quadcore ARMv7) or check the memory size, because of the upgrade to 1GB RAM some register addresses had to relocate, and so any writes there now most be dependent on where the register bank is actually located.
DirkS
Thu Mar 26, 2015 11:12 am
mahjongg wrote:If rpi.GPIO hasn't had an update since the B2 came out then that explains it, all libraries that drive GPIO's must check whether they run on a pre-2B or a 2B or later (on a quadcore ARMv7) or check the memory size, because of the upgrade to 1GB RAM some register addresses had to relocate, and so any writes there now most be dependent on where the register bank is actually located.
It is updated for the Pi2 since 0.5.10 with some fixes in 0.5.11, see https://pypi.python.org/pypi/RPi.GPIO
Current version in the repo also is 0.5.11:
python-rpi.gpio
Installed: 0.5.11-1
Candidate: 0.5.11-1
Version table:
*** 0.5.11-1 0
500 http://archive.raspberrypi.org/debian/ wheezy/main armhf Packages
100 /var/lib/dpkg/status
Cole1717
Mon Mar 30, 2015 10:10 pm
I tried doing what you said @DougieLawson, but it didn't work. it says:
./b.py:5: RuntimeWarning: This channel is already in use, continuing anyway. Use GPIO.setwarnings(False) to disable warnings.
g.setup(17, g.OUT)
Also, "gpio readall" from the terminal is saying "bash: gpio: command not found" .....
Mon Mar 30, 2015 11:37 pm
You need to install the Wiring Pi code.
cd /tmp
git clone git://git.drogon.net/wiringPi
cd wiringPi
./build
Cole1717
Mon Apr 06, 2015 5:18 pm
I installed wiringPi. Ran my simple script and did "gpio readall" while the script was running. The pin isn't changing to output mode, it is staying in input mode with V = 0. Is there an explanation for this?
B.Goode
Mon Apr 06, 2015 5:46 pm
What is in "my simple script". I don't think you have posted a copy of it during this thread?
Cole1717
Tue Apr 07, 2015 10:07 pm
Sorry, I am usually at work when I post. Here is my code that i execute via:
sudo python led.py
import os
import time
import RPi.GPIO as GPIO
GPIO.setmode(GPIO.BOARD)
GPIO.setup(38, GPIO.OUT)
try:
     while True:
              GPIO.output(38, GPIO.HIGH)
except:
     GPIO.cleanup()
B.Goode
Wed Apr 08, 2015 6:51 am
That works OK for me.
Here is the output from the end of a gpio readall command, one run before your script, and one run while your script is executing.
 |  19 |  24 | GPIO.24 |   IN | 0 | 35 || 36 | 0 | IN   | GPIO.27 | 27  | 16  |
 |  26 |  25 | GPIO.25 |   IN | 0 | 37 || 38 | 0 | IN   | GPIO.28 | 28  | 20  |
 |     |     |      0v |      |   | 39 || 40 | 0 | IN   | GPIO.29 | 29  | 21  |
 | BCM | wPi |   Name  | Mode | V | Physical | V | Mode | Name    | wPi | BCM |
 +-----+-----+---------+------+---+---Pi 2---+---+------+---------+-----+-----+
 |  26 |  25 | GPIO.25 |   IN | 0 | 37 || 38 | 1 | OUT  | GPIO.28 | 28  | 20  |
Pin 38 in Board numbering has changed mode to OUT and changed level from 0 to 1.
Cole1717
Wed Apr 08, 2015 11:40 am
That's very strange. I'll try that again when I get the chance. If it doesn't work, do you think re-installing the OS and everything could be worth a try?
joan
Wed Apr 08, 2015 11:42 am
RPi.GPIO only works if you are using device tree. If you are not using device tree that would explain the symptoms you are seeing.
Cole1717
Wed Apr 08, 2015 12:02 pm
I'm fairly certain I left that disabled because I didn't know what it was. What is it exactly? I'll definitely try enabling it.
joan
Wed Apr 08, 2015 12:09 pm
Cole1717 wrote:I'm fairly certain I left that disabled because I didn't know what it was. What is it exactly? I'll definitely try enabling it.
It's something you have to be using if you want to use RPi.GPIO.
I'm not competent to explain its purpose.
If your /boot/config.txt contains a line such as the following then remove it.
device_tree=
Cole1717
Tue Apr 21, 2015 10:44 pm
That worked! thank you so much. Enabled the device tree, rebooted and ran the script and it worked.
Good work team.
proj964
Thu Jun 04, 2015 10:25 am
This thread really helped out. Thanks.
ktb
Thu Jun 04, 2015 11:08 am
proj964 wrote:This thread really helped out. Thanks.
It's nice to see that you got that issue figured out. Good job.
MarkHaysHarris777
Thu Jun 04, 2015 12:35 pm
I thought device tree was enabled by default... did you disable it deliberately or did you find it disabled and left it that way?
marcus
:ugeek:
