edgy
D-Link DWA-121 usb wifi not working?
Fri Jul 06, 2012 9:17 am
Just installed Debian “squeeze” debian6-19-04-2012 with LXDE and I am having problems getting D-Link DWA-121 usb dongle to work. Not having wired internet access doesnt make it any easier.
A GUI for wireless network would be nice if such a thing exist on Debian.
I have no clue what to do. Any ideas?
TimG
Re: D-Link DWA-121 usb wifi not working?
Fri Jul 06, 2012 12:29 pm
I needed to bridge the USB polyfuses to get my WiFi adapter working. Not recommended unless you're fairly experienced at soldering, and confident that the total USB power draw is compatible with the RPi and the power supply. The easier (but klunkier) solution is to use a powered USB hub.
You may or may not need to install a driver. Use iwconfig to see if the WiFi adapter is recognised. Using Debian Wheezy I was lucky. Otherwise look here for info on WiFi drivers: http://wiki.debian.org/WiFi
For configuration I used the command-line tool wpa_supplicant following the instructions here:
http://wiki.debian.org/WiFi/HowToUse#Command_Line
Nr90
Fri Jul 06, 2012 2:40 pm
Wicd is easy to use and gives you a GUI.
I'd try Debian wheezy first as it seems to work much better out of the box.
edgy
Fri Jul 06, 2012 4:42 pm
Thanks helping out. I tried adding a usb hub with power and followed the steps in the Debian wiki. Not much luck.
No networks found with wicd :/
petercal
Wed Jul 11, 2012 7:35 am
I expirence the same problem, my Dlink DWA-121 (N150) is not registrated by the RPI. I have tried
the instructions for r8192u_usb on http://wiki.debian.org/rtl819x#supported-r8192u-usb but the make files does not work on the RPI. - My guess is that the driver must be compiled in the kernel to work with the RPI.
How can this problem be adressed to the right persons in RPI development..???
I'm using latest firmware (rpi-update) on 2012-06-18-wheezy-beta + apt-get upgrade on it
BR,
Peter C
the.hcd
Thu Aug 09, 2012 12:58 pm
petercal wrote:Hi,
Hi Peter,
I've not a dev env set up yet, but have the same usb wifi adapter as you.
The device is operational on adafruit-raspberry-pi-educational-linux-distro/occidentalis-v0-dot-1 which is based on 2012-07-15-wheezy-raspbian
I'm sure you can just copy the binary to your node from this distrib without having to compile.. (unable to attach size is 214k zipped)
pi@raspberrypi:/$ cat /etc/network/interfaces
auto lo
iface lo inet loopback
allow-hotplug wlan1
auto wlan1
iface wlan1 inet static
address 192.168.1.99
netmask 255.255.255.0
gateway 192.168.1.254
wpa-ssid "whiskey"
wpa-psk "bushmills"
pi@raspberrypi:/$ uname -a
Linux raspberrypi 3.1.9adafruit+ #8 PREEMPT Wed Aug 1 18:02:42 EDT 2012 armv6l GNU/Linux
pi@raspberrypi:/$ ifconfig
eth0      Link encap:Ethernet  HWaddr b8:27:eb:bd:24:a5
          UP BROADCAST MULTICAST  MTU:1500  Metric:1
          RX packets:0 errors:0 dropped:0 overruns:0 frame:0
          TX packets:0 errors:0 dropped:0 overruns:0 carrier:0
          collisions:0 txqueuelen:1000
          RX bytes:0 (0.0 B)  TX bytes:0 (0.0 B)
lo        Link encap:Local Loopback
          inet addr:127.0.0.1  Mask:255.0.0.0
          UP LOOPBACK RUNNING  MTU:16436  Metric:1
          collisions:0 txqueuelen:0
wlan1     Link encap:Ethernet  HWaddr cc:b2:55:55:aa:40
          inet addr:192.168.1.99  Bcast:192.168.1.255  Mask:255.255.255.0
          UP BROADCAST RUNNING MULTICAST  MTU:1500  Metric:1
          RX packets:5640 errors:0 dropped:5730 overruns:0 frame:0
          TX packets:3205 errors:0 dropped:0 overruns:0 carrier:0
          RX bytes:8010428 (7.6 MiB)  TX bytes:332778 (324.9 KiB)
pi@raspberrypi:/$ iwconfig
lo        no wireless extensions.
eth0      no wireless extensions.
wlan1     IEEE 802.11bgn  ESSID:"whiskey"  Nickname:"<WIFI@REALTEK>"
          Mode:Managed  Frequency:2.442 GHz  Access Point: F4:CA:E5:F4:1E:FC
          Bit Rate:150 Mb/s   Sensitivity:0/0
          Retry:off   RTS thr:off   Fragment thr:off
          Power Management:off
          Link Quality=100/100  Signal level=72/100  Noise level=0/100
          Rx invalid nwid:0  Rx invalid crypt:0  Rx invalid frag:0
          Tx excessive retries:0  Invalid misc:0   Missed beacon:0
pi@raspberrypi:/$ lsusb
Bus 001 Device 004: ID 2001:3308 D-Link Corp. DWA-121 802.11n Wireless N 150 Pico Adapter [Realtek RTL8188CUS]
Bus 001 Device 005: ID 03f0:0024 Hewlett-Packard KU-0316 Keyboard
pi@raspberrypi:/lib/modules/3.1.9+/kernel/net/wireless$ cat /etc/modules
# /etc/modules: kernel modules to load at boot time.
# This file contains the names of kernel modules that should be loaded
# at boot time, one per line. Lines beginning with "#" are ignored.
# Parameters can be specified after the module name.
snd-bcm2835
# install i2c and spi devices
i2c-bcm2708
i2c-dev
spi-bcm2708
8192cu
pi@raspberrypi:/usr/local/lib$ ls -la /lib/modules/3.1.9+/kernel/drivers/net/wireless/
total 848
drwxr-xr-x 16 root root   4096 Jul 31 20:47 .
drwxr-xr-x  9 root root   4096 Jul 31 03:01 ..
-rw-r--r--  1 root root 616304 Jul 26 02:18 8192cu.ko
[snip]
the.hcd
Thu Aug 09, 2012 1:03 pm
petercal wrote:Hi,
Try to download from my google drive: https://docs.google.com/file/d/0B7uMko3 ... ZRNXM/edit
This is the driver from occidentalis v0.1
petercal
Thu Aug 09, 2012 3:16 pm
Hi
Thans for reply
I got my RPI working with the new driver and this script.
https://dl.dropbox.com/u/12173451/insta ... atest_1.sh
BR
Peter
the.hcd
Tue Sep 25, 2012 4:45 pm
Just to node that on the latest release this usb device works out of the box...
root@raspberrypi:/etc/lirc# uname -a
Linux raspberrypi 3.2.27+ #160 PREEMPT Mon Sep 17 23:18:42 BST 2012 armv6l GNU/Linux
root@raspberrypi:/etc/lirc# lsusb
Bus 001 Device 005: ID 2001:3308 D-Link Corp. DWA-121 802.11n Wireless N 150 Pico Adapter [Realtek RTL8188CUS]
root@raspberrypi:/etc/lirc# iwconfig
wlan0     IEEE 802.11bg  ESSID:"stmury"  Nickname:"<WIFI@REALTEK>"
          Bit Rate:54 Mb/s   Sensitivity:0/0
          Encryption key:****-****-****-****-****-****-****-****   Security mode:open
kloareg
Thu Nov 29, 2012 7:14 pm
The Edimax EW-7811Un wifi adapter is supposed to work on the latest Wheezy but, although it is correctly listed in lsusb, the gui wifi config doesn't recognise it on my machine. However, on the same machine with Occidentalis v0.2, it runs perfectly without any changes to files etc. What's wrong with Wheezy?
Thanks in advance,
Kloareg
If at first you don't succeed, give up!
javierfh
Tue Jun 11, 2013 8:02 pm
petercal wrote:Hi
Thans for reply
BR
Peter
Hi Petercal,
would you be so kind to explain how you installed the new driver? and what is the script, the link to your dropbox seems to be broken.
I have the same dongle and i am getting desperate, can't make it work.
Thanks in advance.
Return to “Debian”
