i think you mean 2013
Orderdate 24 jul 2013 "Raspberry B 512MB cased"
cat /proc/cpuinfo
processor : 0
model name : ARMv6-compatible processor rev 7 (v6l)
BogoMIPS : 2.00
Features : half thumb fastmult vfp edsp java tls
CPU implementer : 0x41
CPU architecture: 7
CPU variant : 0x0
CPU part : 0xb76
CPU revision : 7
Hardware : BCM2708
Revision : 000e
Serial : 000000007ed7ef06
Also in the dmesg there is nothing i can see
notice that the SoHoware is the external usb nic i am currently using
[ 0.000000] Booting Linux on physical CPU 0x0
[ 0.000000] Initializing cgroup subsys cpu
[ 0.000000] Initializing cgroup subsys cpuacct
[ 0.000000] Linux version 3.18.7+ (dc4@dc4-XPS13-9333) (gcc version 4.8.3 201 40303 (prerelease) (crosstool-NG linaro-1.13.1+bzr2650 - Linaro GCC 2014.03) ) # 755 PREEMPT Thu Feb 12 17:14:31 GMT 2015
[ 0.000000] CPU: ARMv6-compatible processor [410fb767] revision 7 (ARMv7), cr =00c5387d
[ 0.000000] CPU: PIPT / VIPT nonaliasing data cache, VIPT nonaliasing instruc tion cache
[ 0.000000] Machine model: Raspberry Pi Model B
[ 0.000000] cma: Reserved 8 MiB at 0x1b800000
[ 0.000000] Memory policy: Data cache writeback
[ 0.000000] On node 0 totalpages: 114688
[ 0.000000] free_area_init_node: node 0, pgdat c084d804, node_mem_map db47400 0
[ 0.000000] Normal zone: 896 pages used for memmap
[ 0.000000] Normal zone: 0 pages reserved
[ 0.000000] Normal zone: 114688 pages, LIFO batch:31
[ 0.000000] pcpu-alloc: s0 r0 d32768 u32768 alloc=1*32768
[ 0.000000] pcpu-alloc: [0] 0
[ 0.000000] Built 1 zonelists in Zone order, mobility grouping on. Total pag es: 113792
[ 0.000000] Kernel command line: dma.dmachans=0x7f35 bcm2708_fb.fbwidth=656 b cm2708_fb.fbheight=416 bcm2708.boardrev=0xe bcm2708.serial=0x7ed7ef06 smsc95xx.m acaddr=B8:27:EB:D7:EF:06 bcm2708_fb.fbswap=1 sdhci-bcm2708.emmc_clock_freq=25000 0000 vc_mem.mem_base=0x1ec00000 vc_mem.mem_size=0x20000000 dwc_otg.lpm_enable=0 console=ttyAMA0,115200 console=tty1 root=/dev/mmcblk0p2 rootfstype=ext4 elevato r=deadline rootwait
[ 0.000000] PID hash table entries: 2048 (order: 1, 8192 bytes)
[ 0.000000] Dentry cache hash table entries: 65536 (order: 6, 262144 bytes)
[ 0.000000] Inode-cache hash table entries: 32768 (order: 5, 131072 bytes)
[ 0.000000] Memory: 437208K/458752K available (5926K kernel code, 358K rwdata , 1876K rodata, 340K init, 734K bss, 21544K reserved)
[ 0.000000] Virtual kernel memory layout:
[ 0.000000] vector : 0xffff0000 - 0xffff1000 ( 4 kB)
[ 0.000000] fixmap : 0xffc00000 - 0xffe00000 (2048 kB)
[ 0.000000] vmalloc : 0xdc800000 - 0xff000000 ( 552 MB)
[ 0.000000] lowmem : 0xc0000000 - 0xdc000000 ( 448 MB)
[ 0.000000] modules : 0xbf000000 - 0xc0000000 ( 16 MB)
[ 0.000000] .text : 0xc0008000 - 0xc07a6ad8 (7803 kB)
[ 0.000000] .init : 0xc07a7000 - 0xc07fc000 ( 340 kB)
[ 0.000000] .data : 0xc07fc000 - 0xc085588c ( 359 kB)
[ 0.000000] .bss : 0xc085588c - 0xc090d128 ( 735 kB)
[ 0.000000] SLUB: HWalign=32, Order=0-3, MinObjects=0, CPUs=1, Nodes=1
[ 0.000000] Preemptible hierarchical RCU implementation.
[ 0.000000] NR_IRQS:522
[ 0.000023] sched_clock: 32 bits at 1000kHz, resolution 1000ns, wraps every 2 147483648000ns
[ 0.000074] Switching to timer-based delay loop, resolution 1000ns
[ 0.000353] Console: colour dummy device 80x30
[ 0.001409] console [tty1] enabled
[ 0.001455] Calibrating delay loop (skipped), value calculated using timer fr equency.. 2.00 BogoMIPS (lpj=10000)
[ 0.001529] pid_max: default: 32768 minimum: 301
[ 0.001908] Mount-cache hash table entries: 1024 (order: 0, 4096 bytes)
[ 0.001974] Mountpoint-cache hash table entries: 1024 (order: 0, 4096 bytes)
[ 0.002980] Initializing cgroup subsys memory
[ 0.003072] Initializing cgroup subsys devices
[ 0.003132] Initializing cgroup subsys freezer
[ 0.003185] Initializing cgroup subsys net_cls
[ 0.003237] Initializing cgroup subsys blkio
[ 0.003359] CPU: Testing write buffer coherency: ok
[ 0.003473] ftrace: allocating 19479 entries in 58 pages
[ 0.111553] Setting up static identity map for 0x55d058 - 0x55d0b4
[ 0.114371] devtmpfs: initialized
[ 0.131819] VFP support v0.3: implementor 41 architecture 1 part 20 variant b rev 5
[ 0.134999] pinctrl core: initialized pinctrl subsystem
[ 0.137661] NET: Registered protocol family 16
[ 0.143128] DMA: preallocated 4096 KiB pool for atomic coherent allocations
[ 0.171326] cpuidle: using governor ladder
[ 0.201384] cpuidle: using governor menu
[ 0.201891] bcm2708.uart_clock = 3000000
[ 0.204982] No ATAGs?
[ 0.205047] hw-breakpoint: found 6 breakpoint and 1 watchpoint registers.
[ 0.205107] hw-breakpoint: maximum watchpoint size is 4 bytes.
[ 0.205174] mailbox: Broadcom VideoCore Mailbox driver
[ 0.205334] bcm2708_vcio: mailbox at f200b880
[ 0.205803] bcm_power: Broadcom power driver
[ 0.205859] bcm_power_open() -> 0
[ 0.205890] bcm_power_request(0, 8)
[ 0.706630] bcm_mailbox_read -> 00000080, 0
[ 0.706676] bcm_power_request -> 0
[ 0.706874] Serial: AMBA PL011 UART driver
[ 0.707111] dev:f1: ttyAMA0 at MMIO 0x20201000 (irq = 83, base_baud = 0) is a PL011 rev3
[ 1.096537] console [ttyAMA0] enabled
[ 1.169587] SCSI subsystem initialized
[ 1.173716] usbcore: registered new interface driver usbfs
[ 1.179511] usbcore: registered new interface driver hub
[ 1.185029] usbcore: registered new device driver usb
[ 1.192202] Switched to clocksource stc
[ 1.226570] FS-Cache: Loaded
[ 1.229889] CacheFiles: Loaded
[ 1.250058] NET: Registered protocol family 2
[ 1.256010] TCP established hash table entries: 4096 (order: 2, 16384 bytes)
[ 1.263422] TCP bind hash table entries: 4096 (order: 2, 16384 bytes)
[ 1.269981] TCP: Hash tables configured (established 4096 bind 4096)
[ 1.276487] TCP: reno registered
[ 1.279755] UDP hash table entries: 256 (order: 0, 4096 bytes)
[ 1.285681] UDP-Lite hash table entries: 256 (order: 0, 4096 bytes)
[ 1.292432] NET: Registered protocol family 1
[ 1.297440] RPC: Registered named UNIX socket transport module.
[ 1.303523] RPC: Registered udp transport module.
[ 1.308253] RPC: Registered tcp transport module.
[ 1.313019] RPC: Registered tcp NFSv4.1 backchannel transport module.
[ 1.320683] bcm2708_dma: DMA manager at f2007000
[ 1.325713] vc-mem: phys_addr:0x00000000 mem_base=0x1ec00000 mem_size:0x20000 000(512 MiB)
[ 1.335594] futex hash table entries: 256 (order: -1, 3072 bytes)
[ 1.341862] audit: initializing netlink subsys (disabled)
[ 1.347582] audit: type=2000 audit(1.100:1): initialized
[ 1.368440] VFS: Disk quotas dquot_6.5.2
[ 1.372939] Dquot-cache hash table entries: 1024 (order 0, 4096 bytes)
[ 1.382412] FS-Cache: Netfs 'nfs' registered for caching
[ 1.389517] NFS: Registering the id_resolver key type
[ 1.394834] Key type id_resolver registered
[ 1.399049] Key type id_legacy registered
[ 1.404593] msgmni has been set to 869
[ 1.410886] Block layer SCSI generic (bsg) driver version 0.4 loaded (major 2 52)
[ 1.418900] io scheduler noop registered
[ 1.423045] io scheduler deadline registered (default)
[ 1.428602] io scheduler cfq registered
[ 1.435169] BCM2708FB: allocated DMA memory 5bc00000
[ 1.440236] BCM2708FB: allocated DMA channel 0 @ f2007000
[ 1.451696] Console: switching to colour frame buffer device 82x26
[ 1.464029] bcm2708-dmaengine bcm2708-dmaengine: Load BCM2835 DMA engine driv er
[ 1.473647] uart-pl011 dev:f1: no DMA platform data
[ 1.481065] vc-cma: Videocore CMA driver
[ 1.486820] vc-cma: vc_cma_base = 0x00000000
[ 1.493234] vc-cma: vc_cma_size = 0x00000000 (0 MiB)
[ 1.500204] vc-cma: vc_cma_initial = 0x00000000 (0 MiB)
[ 1.520771] brd: module loaded
[ 1.532755] loop: module loaded
[ 1.537942] vchiq: vchiq_init_state: slot_zero = 0xdb800000, is_master = 0
[ 1.547587] Loading iSCSI transport class v2.0-870.
[ 1.555854] usbcore: registered new interface driver smsc95xx
[ 1.563511] dwc_otg: version 3.00a 10-AUG-2012 (platform bus)
[ 1.771105] Core Release: 2.80a
[ 1.775946] Setting default values for core params
[ 1.782310] Finished setting default values for core params
[ 1.989585] Using Buffer DMA mode
[ 1.994493] Periodic Transfer Interrupt Enhancement - disabled
[ 2.001882] Multiprocessor Interrupt Enhancement - disabled
[ 2.009062] OTG VER PARAM: 0, OTG VER FLAG: 0
[ 2.015046] Dedicated Tx FIFOs mode
[ 2.020550] WARN::dwc_otg_hcd_init:1047: FIQ DMA bounce buffers: virt = 0xdbc 14000 dma = 0x5bc14000 len=9024
[ 2.033618] FIQ FSM acceleration enabled for :
[ 2.033618] Non-periodic Split Transactions
[ 2.033618] Periodic Split Transactions
[ 2.033618] High-Speed Isochronous Endpoints
[ 2.056670] dwc_otg: Microframe scheduler enabled
[ 2.056775] WARN::hcd_init_fiq:412: FIQ on core 0 at 0xc040116c
[ 2.064378] WARN::hcd_init_fiq:413: FIQ ASM at 0xc0401444 length 36
[ 2.072318] WARN::hcd_init_fiq:438: MPHI regs_base at 0xdc806000
[ 2.080035] dwc_otg bcm2708_usb: DWC OTG Controller
[ 2.086636] dwc_otg bcm2708_usb: new USB bus registered, assigned bus number 1
[ 2.095626] dwc_otg bcm2708_usb: irq 32, io mem 0x00000000
[ 2.102810] Init: Port Power? op_state=1
[ 2.108314] Init: Power Port (0)
[ 2.113532] usb usb1: New USB device found, idVendor=1d6b, idProduct=0002
[ 2.121979] usb usb1: New USB device strings: Mfr=3, Product=2, SerialNumber= 1
[ 2.130874] usb usb1: Product: DWC OTG Controller
[ 2.137216] usb usb1: Manufacturer: Linux 3.18.7+ dwc_otg_hcd
[ 2.144597] usb usb1: SerialNumber: bcm2708_usb
[ 2.151853] hub 1-0:1.0: USB hub found
[ 2.157464] hub 1-0:1.0: 1 port detected
[ 2.163695] dwc_otg: FIQ enabled
[ 2.163720] dwc_otg: NAK holdoff enabled
[ 2.163732] dwc_otg: FIQ split-transaction FSM enabled
[ 2.163794] Module dwc_common_port init
[ 2.164367] usbcore: registered new interface driver usb-storage
[ 2.172611] mousedev: PS/2 mouse device common for all mice
[ 2.180630] bcm2835-cpufreq: min=700000 max=700000
[ 2.187531] sdhci: Secure Digital Host Controller Interface driver
[ 2.195444] sdhci: Copyright(c) Pierre Ossman
[ 2.201671] DMA channels allocated for the MMC driver
[ 2.242283] Load BCM2835 MMC driver
[ 2.249339] sdhci-pltfm: SDHCI platform and OF driver helper
[ 2.265188] ledtrig-cpu: registered to indicate activity on CPUs
[ 2.273290] hidraw: raw HID events driver (C) Jiri Kosina
[ 2.285027] usbcore: registered new interface driver usbhid
[ 2.294425] usbhid: USB HID core driver
[ 2.302513] TCP: cubic registered
[ 2.308660] Initializing XFRM netlink socket
[ 2.316806] NET: Registered protocol family 17
[ 2.323320] Key type dns_resolver registered
[ 2.330933] registered taskstats version 1
[ 2.336992] vc-sm: Videocore shared memory driver
[ 2.343449] [vc_sm_connected_init]: start
[ 2.350148] [vc_sm_connected_init]: end - returning 0
[ 2.358524] Waiting for root device /dev/mmcblk0p2...
[ 2.365661] Indeed it is in host mode hprt0 = 00021501
[ 2.379797] mmc0: host does not support reading read-only switch, assuming wr ite-enable
[ 2.405512] mmc0: new high speed SDHC card at address 45c9
[ 2.422976] mmcblk0: mmc0:45c9 SD16G 14.7 GiB
[ 2.444506] mmcblk0: p1 p2
[ 2.507217] EXT4-fs (mmcblk0p2): mounted filesystem with ordered data mode. O pts: (null)
[ 2.518996] VFS: Mounted root (ext4 filesystem) readonly on device 179:2.
[ 2.529973] devtmpfs: mounted
[ 2.535998] Freeing unused kernel memory: 340K (c07a7000 - c07fc000)
[ 2.572484] usb 1-1: new high-speed USB device number 2 using dwc_otg
[ 2.581014] Indeed it is in host mode hprt0 = 00001101
[ 2.792885] usb 1-1: New USB device found, idVendor=0424, idProduct=9512
[ 2.802706] usb 1-1: New USB device strings: Mfr=0, Product=0, SerialNumber=0
[ 2.813729] hub 1-1:1.0: USB hub found
[ 2.820553] hub 1-1:1.0: 3 ports detected
[ 3.102539] usb 1-1.1: new high-speed USB device number 3 using dwc_otg
[ 3.212981] usb 1-1.1: New USB device found, idVendor=0424, idProduct=ec00
[ 3.221945] usb 1-1.1: New USB device strings: Mfr=0, Product=0, SerialNumber =0
[ 3.253013] smsc95xx v1.0.4
[ 3.321341] smsc95xx 1-1.1:1.0 eth0: register 'smsc95xx' at usb-bcm2708_usb-1 .1, smsc95xx USB 2.0 Ethernet, b8:27:eb:d7:ef:06
[ 3.432646] usb 1-1.2: new full-speed USB device number 4 using dwc_otg
[ 3.581631] usb 1-1.2: New USB device found, idVendor=15e8, idProduct=9100
[ 3.599118] usb 1-1.2: New USB device strings: Mfr=1, Product=2, SerialNumber =3
[ 3.617527] usb 1-1.2: Product: SOHOware[TM] 10/100 USB
[ 3.631608] usb 1-1.2: Manufacturer: NDC
[ 3.650952] usb 1-1.2: SerialNumber: 0001
[ 4.248093] udevd[159]: starting version 175
[ 5.670201] pegasus: v0.9.3 (2013/04/25), Pegasus/Pegasus II USB Ethernet driver
[ 5.814207] pegasus 1-1.2:1.0: eth1, SOHOware NUB100 Ethernet, 00:80:c6:f3:83:b1
[ 6.034511] usbcore: registered new interface driver pegasus
[ 10.506231] EXT4-fs (mmcblk0p2): re-mounted. Opts: (null)
[ 10.964106] EXT4-fs (mmcblk0p2): re-mounted. Opts: (null)
[ 11.472340] random: nonblocking pool is initialized
[ 20.722791] smsc95xx 1-1.1:1.0 eth0: hardware isn't capable of remote wakeup
[ 22.175701] smsc95xx 1-1.1:1.0 eth0: link up, 100Mbps, full-duplex, lpa 0x4DE 1
[ 28.936043] Adding 102396k swap on /var/swap. Priority:-1 extents:2 across:2 134012k SSFS
