oliverrose99
phpmyadmin navigation.php not found [FIXED]
Mon Mar 09, 2015 8:32 pm
Hi
I just installed phpmyadmin on Apache and configured it to connect to a remote server but when I go to the site it says "The requested URL /phpmyadmin/navigation.php< was not found on this server." I checked the directory and navigation.php is there. Any ideas?
Thanks.
EDIT
I have fixed the issue by completely redoing everything. Have no idea why it didn't work
Re: phpmyadmin navigation.php not found
Mon Mar 09, 2015 8:48 pm
In /etc/apache2/conf.d you should have a symlink
lrwxrwxrwx 1 root root 28 Mmm dd hh:mm phpmyadmin.conf -> ../../phpmyadmin/apache.conf
If that's there have you restarted Apache2 after you installed phpmyadmin?
oliverrose99
Mon Mar 09, 2015 9:04 pm
I'm getting permission denied with "sudo lrwxrwxrwx 1 root root 28 Mmm dd hh:mm phpmyadmin.conf -> ../../phpmyadmin/apache.conf"
I've added 'Include /etc/phpmyadmin/apache.conf' to apache2.conf following a guide but it normally works
Mon Mar 09, 2015 9:13 pm
Use the ls command to see if the symlink exists. Don't try to type in my sample output as a command, that won't work.
ioha
Mon Mar 09, 2015 9:25 pm
you could provide the output of:
ls -l /etc/apache2/conf.d/phpmyadmin.conf
Raspberry Pi 1 Model B+ (since 2014-08-10): Raspbian jessie / Debian 8.1
Raspberry Pi 2 Model B (since 2015-03-10): OpenELEC 5.0.8
oliverrose99
Mon Mar 09, 2015 9:31 pm
DougieLawson wrote:Use the ls command to see if the symlink exists. Don't try to type in my sample output as a command, that won't work.
Sorry, I'm still a noob. can you clarify what directory/file i'm linking and where to.
Re: phpmyadmin navigation.php not found [FIXED]
Mon Mar 09, 2015 10:08 pm
When you install phpmyadmin it doesn't get installed directly into /etc/apache2 it gets installed in /etc/phpmyadmin. So that you don't end up with duplicate copies of configuration files Linux has a system called symbolic links, it's basically a file system pointer.
When the system tries to read /etc/apache2/conf.d/phpmyadmin.conf it follows the symbolic link and looks at /etc/phpmyadmin/apache.conf instead. If that link is missing then phpmyadmin won't work.
Try this to fix it
sudo apt-get install --reinstall phpmyadmin
sudo service apache2 restart
aqk
Wed Jan 13, 2016 7:26 am
OK- came across this forum just now.
I have had a R-Pi working as a file server for my two desktops and a laptop for some time.
The Pi dangles precariously from its Ethernet cable (and its USB power cable) underneath my router on a shelf.
I obviously DO NOT have a monitor connected to it. Instead, I use PuTTY to communicate with it.
The Raspian version of LAMP was installed on it and the web-server works quite well.
Using 192.168....etc,,.. I can get a home page (with PHP) as well as my local webhost pages.
viz my home page:
Raspberry Apache-PHP server:
Server signature is- Apache/2.2.22 (Debian) Server at 192.168.200.99 Port 80
and your system is using:
Mozilla/5.0 (Windows NT 10.0; WOW64; rv:43.0) Gecko/20100101 Firefox/43.0
PHPMYADMIN has been installed - :
Building dependency tree
phpmyadmin is already the newest version.
0 upgraded, 0 newly installed, 0 to remove and 23 not upgraded.
However, when I enter 192.168.200.99/phpmyadmin in my web-browser, it returns a 404.
What more do I have to do to get PHPMYADMIN - and MYSQL - working?
Wed Jan 13, 2016 1:44 pm
aqk wrote:However, when I enter 192.168.200.99/phpmyadmin in my web-browser, it returns a 404.
I don't know.
I just tested this. I installed Raspbian Jessie Lite. Then apt-get install apache2, followed by mysql-server, then phpmyadmin, and it worked first time.
aqk
Wed Jan 13, 2016 6:48 pm
OK-
Tried the commands above (via a PuTTY port) and got:
aqk@raspberrypi ~ $sudo apt-get install --reinstall phpmyadmin
Reading package lists... Done
0 upgraded, 0 newly installed, 1 reinstalled, 0 to remove and 23 not upgraded.
Need to get 0 B/5,503 kB of archives.
After this operation, 0 B of additional disk space will be used.
Preconfiguring packages ...
(Reading database ... 79456 files and directories currently installed.)
Preparing to replace phpmyadmin 4:3.4.11.1-2+deb7u1 (using .../phpmyadmin_4%3a3.4.11.1-2+deb7u1_all.deb) ...
Unpacking replacement phpmyadmin ...
Processing triggers for hicolor-icon-theme ...
Processing triggers for man-db ...
Setting up phpmyadmin (4:3.4.11.1-2+deb7u1) ...
dbconfig-common: writing config to /etc/dbconfig-common/phpmyadmin.conf
Replacing config file /etc/phpmyadmin/config-db.php with new version
dbconfig-common: flushing administrative password[/size]
aqk@raspberrypi ~ $ sudo service apache2 restart
Restarting web server: apache2 ... waiting .
aqk@raspberrypi ~ $
I still get
Not Found
The requested URL /phpmyadmin was not found on this server.
Any ideas?
Wed Jan 13, 2016 7:33 pm
Ok, in /etc/apache2/conf-enabled you should have a file called phpmyadmin.conf. That is a link to /etc/apache2/conf-available/phpmyadmin.conf which in turn is a link to /etc/phpmyadmin/apache.conf.
For a start, all of those files need to exist for phpmydmin to work.
rpdom@oz:/etc/apache2/conf-enabled$ ls -l phpmyadmin.conf
lrwxrwxrwx 1 root root 33 Jan 13 13:38 phpmyadmin.conf -> ../conf-available/phpmyadmin.conf
rpdom@oz:/etc/apache2/conf-enabled$ cd ../conf-available/
rpdom@oz:/etc/apache2/conf-available$ ls -l phpmyadmin.conf
lrwxrwxrwx 1 root root 28 Jan 13 13:38 phpmyadmin.conf -> ../../phpmyadmin/apache.conf
rpdom@oz:/etc/apache2/conf-available$ cd ../../phpmyadmin/
rpdom@oz:/etc/phpmyadmin$ ls -l apache.conf
-rw-r--r-- 1 root root 1397 Oct 28 16:32 apache.conf
