cosmo
Raspberry Pi 2 doesn't boot, original Model B does (solved)
Mon Mar 09, 2015 2:51 pm
I have a new Raspberry Pi 2 which I cn't get to work. I get no activity on the startup LEDs (Only the red light is lit, no blinking green light).
I tried using the same SD card/power supply with one of my older model B, and everything works properly. I tried with 2 different power supplies, with the same result with both of them. I only have one Micro SD card to try this on, so I can't verify that it is the card or not. I loaded the latest OpenElec distribution and that boots up properly with the older model, but all I get with the new computer is the rainbow screen.
Is there anything different about the newer model that would prevent it from working with a card and components that work on the older model (I also have a WiFi adapter and an adapter for a wireless mouse connected, and both work with the older model)? Is there a way to determine if I have a bad computer or if there is something else I can try?
Re: Raspberry Pi 2 doesn't boot, original Model B does
Mon Mar 09, 2015 2:55 pm
cosmo wrote:I have a new Raspberry Pi 2 which I cn't get to work. I get no activity on the startup LEDs (Only the red light is lit, no blinking green light).
OpenElec have different version for the RPi2 B http://openelec.tv/get-openelec
RPi 4B 4GB (SSD Boot)..
cosmo
Mon Mar 09, 2015 3:29 pm
Ok, thanks. I was hoping it was something simple like this. I had downloaded the latest from this site (http://www.raspberrypi.org/downloads/), didn't realize there was a different download for the multiprocessor model. I'll test this out when I get a chance.
Haven't had a chance to try out Raspbian or any other os just yet. Are there different versions of the other systems for the multiprocessor model as well?
Thanks again! Much appreciated.
DirkS
Mon Mar 09, 2015 3:35 pm
cosmo wrote:Haven't had a chance to try out Raspbian or any other os just yet. Are there different versions of the other systems for the multiprocessor model as well?
If you click on one of the 'more info' links on the downloads page Pi1 / Pi2 compatibility information should show up.
Last time I looked only Raspbian and Snappy downloads were Pi2B compatible.
Mon Mar 09, 2015 3:55 pm
Raspbian latest version is suitable for all versions of the RPi
Raspbmc has been obsoleted and replaced by OSMC, though different versions for RPi1 & 2 https://osmc.tv/download/images
Arch Linux Arm also have different versions for RPi1 & 2
cherokee
Tue Mar 10, 2015 12:50 pm
Although they claim the Pi2 to be "completely compatible" with the Pi1, I've found that a card installed on the Pi1 will not boot the Pi2 but just produce the "rainbow screen". I haven't tried it v.v. yet, but my guess is that it'll be the same, as at least parts of the SoC most likely need to be adressed differently.
So just try and copy NOOBS (or whatever else) onto a new micro sd card (or clear your current one) and go through the installation process on your Pi2 and you should be ok.
RPi B+ / RPi 2 // Raspbian / OpenElec / Retropie // DSL 40.7 Mbit/s
mahjongg
Tue Mar 10, 2015 6:36 pm
You need a new compatible kernel, and it will work on both systems, You can do an upgrade for that, info at multiple places:
http://www.raspberrypi.org/forums/viewt ... 46#p695146
and
http://www.raspberrypi.org/forums/viewt ... 28&t=58151
Read the stickies!
cherokee
Wed Mar 11, 2015 4:25 pm
I tried a.m. method yesterday and it undoubtedly works, although you may need a lot of time. The upgrade took more than an hour and the dist-upgrade took more than three hours on my Pi B+. Also at least some of my settings (config.txt) were overwritten with default values, so be sure to save your setting first.
Anyway, I found the all new installation onto a clean memory card to be the easier and much faster way.
cosmo
Wed Mar 11, 2015 9:30 pm
Thanks for the replies, I was able to get the card to work using the proper distribution. Now I'm waiting for another card so I can set up the Raspbian OS.
Thanks again!
pixster
Re: Raspberry Pi 2 doesn't boot, original Model B does (solv
Mon Mar 16, 2015 2:03 am
With a fresh copy of Wheezy, it boots just fine!
NO, an already running copy of Wheezy brought up on
a Pi 1 WON'T work on a Pi 2!! :roll:
Were talking about 2 different SoC's BCM2835 vs BCM2836
Mon Mar 16, 2015 7:27 am
pixster wrote:With a fresh copy of Wheezy, it boots just fine!
Unless you run sudo apt-get update;sudo apt-get upgrade on the Pi 1 first. (and some voodoo stuff if you have NOOBS).
pixster
Fri Mar 27, 2015 6:58 pm
A fresh download of Wheezy from their home sight boots just fine. Forget noobs! :ugeek:
