I am running on a nobis install this time
I have basically a duel/boot card here with raspbian2015 and OpenElec with KODI
I did buy the codecs from the pi store
say when in raspbian i can run the command sudo nano /boot/config.txt it opens in the terminal to a blank page in the term,, then when i try to add the codecs then hit ctl/x and tney hit y to accept i get a error for it tells me iit is a read only file
now i can go int sudo nano /boot.bak/config.txt and access it. I can install the codecs this way,, hit ctl/x then y and it accepts it.. here is the code i get
'# For more options and information see
# http://www.raspberrypi.org/documentation/configuration/config-txt.md# Some settings may impact device functionality. See link above for details
# uncomment if you get no picture on HDMI for a default "safe" mode
#hdmi_safe=1
uncomment this if your display has a black border of unused pixels visible
and your display can output without overscan
disable_overscan=1
# uncomment the following to adjust overscan. Use positive numbers if console
# goes off screen, and negative if there is too much border
#overscan_left=16
#overscan_right=16
#overscan_top=16
#overscan_bottom=16
# uncomment to force a console size. By default it will be display's size minus
# overscan.
#framebuffer_width=1280
#framebuffer_height=720
#hdmi_force_hotplug=1
# uncomment to force a specific HDMI mode (this will force VGA)
#hdmi_group=1
#hdmi_mode=1
# uncomment to force a HDMI mode rather than DVI. This can make audio work in
# DMT (computer monitor) modes
#hdmi_drive=2
# uncomment to increase signal to HDMI, if you have interference, blanking, or
# no display
#config_hdmi_boost=4
# uncomment for composite PAL
#sdtv_mode=2
#uncomment to overclock the arm. 700 MHz is the default.
arm_freq=900
decode_MPG2=0
decode_WVC1=0
# NOOBS Auto-generated Settings:
config_hdmi_boost=4
overscan_left=24
overscan_right=24
overscan_top=16
overscan_bottom=16
disable_overscan=0
core_freq=250
sdram_freq=450
over_voltage=2"
yet when i run the command to check to see if they are enabled well here is the code
pi@raspberrypi ~ $ vcgencmd codec_enabled MPG2
MPG2=disabled
pi@raspberrypi ~ $ vcgencmd codec_enabled WVC1
WVC1=disabled
pi@raspberrypi ~ $
