neil0174
No picture on HDMI
Wed Jul 04, 2012 6:23 pm
I'm having HDMI issues with my Pi and my Sony KDL-40W5710 TV.
When then Pi boots, the TV detects the signal and switches to the appropriate HDMI channel. The OSD even says BCM2763 so it's receiving some data from the Pi, just no picture!
I've uploaded the latest firmware using hexxeh's tool and i'm running Wheezy.
I've tried just about every config.txt change (including no config.txt) that I've found on other forum posts, including all the usual hdmi_safe=1 and setting other various mode settings (hdmi_force_hotplug=1, hdmi_drive, hdmi_mode, hdmi_group etc) but still no output at all. I've tried two different HDMI cables (which work with my sky box -> tv).
Going in via PuTTY i've got hold of the following EDID info (below)
I've run out of ideas and Linux knowledge. Any help would be appreciated!
Neil.
[email protected] ~ $ uname -a
Linux raspberrypi 3.1.9+ #144 PREEMPT Sun Jul 1 12:37:10 BST 2012 armv6l GNU/Linux
[email protected] ~ $  /opt/vc/bin/vcgencmd version
Jul  1 2012 12:48:16
Copyright (c) 2012 Broadcom
version 323014 (release)
[email protected] ~ $ /opt/vc/bin/tvservice -s
state: HPD high|HDMI mode|HDCP off|composite off (0x12001a), 1920x1080 @ 60Hz, progressive
[email protected] ~ $ /opt/vc/bin/tvservice -m CEA
Group CEA has 16 modes:
           mode 1: 640x480 @ 60Hz, progressive
           mode 2: 720x480 @ 60Hz, progressive
           mode 3: 720x480 @ 60Hz, progressive
           mode 4: 1280x720 @ 60Hz, progressive
           mode 5: 1920x1080 @ 60Hz, interlaced
           mode 6: 720x480 @ 60Hz, interlaced
           mode 7: 720x480 @ 60Hz, interlaced
  (native) mode 16: 1920x1080 @ 60Hz, progressive
           mode 17: 720x576 @ 50Hz, progressive
           mode 18: 720x576 @ 50Hz, progressive
           mode 19: 1280x720 @ 50Hz, progressive
           mode 20: 1920x1080 @ 50Hz, interlaced
           mode 21: 720x576 @ 50Hz, interlaced
           mode 22: 720x576 @ 50Hz, interlaced
           mode 31: 1920x1080 @ 50Hz, progressive
           mode 32: 1920x1080 @ 24Hz, progressive
[email protected] ~ $ /opt/vc/bin/tvservice -m DMT
Group DMT has 4 modes:
           mode 4: 640x480 @ 60Hz, progressive
           mode 9: 800x600 @ 60Hz, progressive
           mode 16: 1024x768 @ 60Hz, progressive
           mode 35: 1280x1024 @ 60Hz, progressive
[email protected] ~ $ /opt/vc/bin/tvservice -d edid.dat
Written 256 bytes to edid.dat
[email protected] ~ $ /opt/vc/bin/edidparser edid.dat
Parsing edid.dat...
HDMI:EDID version 1.3, 1 extensions, screen size 160x90 cm
HDMI:EDID features - videodef 0x80 !standby !suspend !active off; colour encoding:RGB444|YCbCr422; sRGB is not default colourspace; preferred format is native; does not support GTF
HDMI:EDID found monitor name descriptor tag 0xfc
HDMI:EDID monitor name is SONY_TV
HDMI:EDID found monitor range descriptor tag 0xfd
HDMI:EDID monitor range offsets: V min=0, V max=0, H min=0, H max=0
HDMI:EDID monitor range: vertical is 48-62 Hz, horizontal is 14-70 kHz, max pixel clock is 150 MHz
HDMI:EDID monitor range does not support GTF
HDMI:EDID found preferred CEA detail timing format: 1920x1080p @ 60 Hz (16)
HDMI:EDID found CEA detail timing format: 1280x720p @ 60 Hz (4)
HDMI:EDID established timing I/II bytes are 21 08 00
HDMI:EDID found DMT format: code 4, 640x480p @ 60 Hz in established timing I/II
HDMI:EDID found DMT format: code 9, 800x600p @ 60 Hz in established timing I/II
HDMI:EDID found DMT format: code 16, 1024x768p @ 60 Hz in established timing I/II
HDMI:EDID standard timings block x 8: 0x8180 0101 0101 0101 0101 0101 0101 0101
HDMI:EDID found DMT format: code 35, 1280x1024p @ 60 Hz (5:4) in standard timing 0
HDMI:EDID parsing v3 CEA extension 0
HDMI:EDID monitor support - underscan IT formats:yes, basic audio:yes, yuv444:yes, yuv422:yes, #native DTD:0
HDMI:EDID found CEA detail timing format: 1920x1080p @ 50 Hz (31)
HDMI:EDID found CEA detail timing format: 1280x720p @ 50 Hz (19)
HDMI:EDID found CEA detail timing format: 1920x1080i @ 60 Hz (5)
HDMI:EDID found CEA detail timing format: 1920x1080i @ 50 Hz (20)
HDMI:EDID found CEA format: code 31, 1920x1080p @ 50Hz
HDMI:EDID found CEA format: code 16, 1920x1080p @ 60Hz
HDMI:EDID found CEA format: code 20, 1920x1080i @ 50Hz
HDMI:EDID found CEA format: code 5, 1920x1080i @ 60Hz
HDMI:EDID found CEA format: code 19, 1280x720p @ 50Hz
HDMI:EDID found CEA format: code 4, 1280x720p @ 60Hz
HDMI:EDID found CEA format: code 18, 720x576p @ 50Hz
HDMI:EDID found CEA format: code 17, 720x576p @ 50Hz
HDMI:EDID found CEA format: code 22, 1440x576i @ 50Hz
HDMI:EDID found CEA format: code 21, 1440x576i @ 50Hz
HDMI:EDID found CEA format: code 3, 720x480p @ 60Hz
HDMI:EDID found CEA format: code 2, 720x480p @ 60Hz
HDMI:EDID found CEA format: code 7, 1440x480i @ 60Hz
HDMI:EDID found CEA format: code 6, 1440x480i @ 60Hz
HDMI:EDID found CEA format: code 1, 640x480p @ 60Hz
HDMI:EDID found CEA format: code 32, 1920x1080p @ 24Hz
HDMI:EDID found audio format 2 channels PCM, sample rate: 32|44|48 kHz, sample size: 16|20|24 bits
HDMI:EDID found audio format 6 channels AC3, sample rate: 32|44|48 kHz, bitrate: 640 kbps
HDMI:EDID found HDMI VSDB length 8
HDMI:EDID HDMI VSDB has physical address 3.0.0.0
HDMI:EDID HDMI VSDB supports AI:yes, dual link DVI:no
HDMI:EDID HDMI VSDB deep colour support - 48-bit:no 36-bit:no 30-bit:no DC_yuv444:no
HDMI:EDID HDMI VSDB max TMDS clock 0 MHz
HDMI:EDID HDMI VSDB content type support: game|cinema|photo|text
HDMI:EDID found Video Capability DB length 2
HDMI:EDID video capability: CE:3 IT:2 PT:3 QS:1
HDMI:EDID filtering formats with pixel clock > 162 MHz or h. blanking > 1023
HDMI:EDID best score mode is now CEA (1) 640x480p @ 60 Hz with pixel clock 25 MHz (score 136864)
HDMI:EDID best score mode is now CEA (2) 720x480p @ 60 Hz with pixel clock 27 MHz (score 141472)
HDMI:EDID CEA mode (3) 720x480p @ 60 Hz with pixel clock 27 MHz has a score of 141472
HDMI:EDID best score mode is now CEA (4) 1280x720p @ 60 Hz with pixel clock 74 MHz (score 4710592)
HDMI:EDID DMT mode (4) 640x480p @ 60 Hz with pixel clock 25 MHz has a score of 18432
HDMI:EDID CEA mode (5) 1920x1080i @ 60 Hz with pixel clock 74 MHz has a score of 3348832
HDMI:EDID CEA mode (6) 1440x480i @ 60 Hz with pixel clock 27 MHz has a score of 120736
HDMI:EDID CEA mode (7) 1440x480i @ 60 Hz with pixel clock 27 MHz has a score of 120736
HDMI:EDID DMT mode (9) 800x600p @ 60 Hz with pixel clock 40 MHz has a score of 28800
HDMI:EDID best score mode is now CEA (16) 1920x1080p @ 60 Hz with pixel clock 148 MHz (score 5473248)
HDMI:EDID DMT mode (16) 1024x768p @ 60 Hz with pixel clock 65 MHz has a score of 47185
HDMI:EDID CEA mode (17) 720x576p @ 50 Hz with pixel clock 27 MHz has a score of 141472
HDMI:EDID CEA mode (18) 720x576p @ 50 Hz with pixel clock 27 MHz has a score of 141472
HDMI:EDID CEA mode (19) 1280x720p @ 50 Hz with pixel clock 74 MHz has a score of 3692160
HDMI:EDID CEA mode (20) 1920x1080i @ 50 Hz with pixel clock 74 MHz has a score of 2807360
HDMI:EDID CEA mode (21) 1440x576i @ 50 Hz with pixel clock 27 MHz has a score of 120736
HDMI:EDID CEA mode (22) 1440x576i @ 50 Hz with pixel clock 27 MHz has a score of 120736
HDMI:EDID CEA mode (31) 1920x1080p @ 50 Hz with pixel clock 148 MHz has a score of 4307360
HDMI:EDID CEA mode (32) 1920x1080p @ 24 Hz with pixel clock 74 MHz has a score of 199532
HDMI:EDID DMT mode (35) 1280x1024p @ 60 Hz with pixel clock 108 MHz has a score of 178643
HDMI:EDID preferred mode remained as CEA (16) 1920x1080p @ 60 Hz with pixel clock 148 MHz
HDMI:EDID has HDMI support and audio support
edid_parser exited with code 0
Nr90
Re: No picture on HDMI
Wed Jul 04, 2012 6:43 pm
Did you also try:
config_hdmi_boost configure the signal strength of the HDMI interface. Default is 0. Try 4 if you have interference issues with hdmi. 7 is the maximum.
neil0174
Wed Jul 04, 2012 6:54 pm
Just tried config_hdmi_boost=7 (had previously tried 4) but still no picture (it's completely blank).
dom
Wed Jul 04, 2012 6:55 pm
That EDID looks straightforward. This feels like a hardware fault.
One last check. Remove everything from config.txt (including hdmi_safe=1) and add config_hdmi_boost=7.
(I don't expect that to work).
If you can swap you Pi with a friend's, then that's the best test.
If you can plug the Pi into someone else's HDMI TV (and their cable), that is other useful test.
Have a close look at the HDMI socket on the Pi. Check no pins are bent inside, and there is nothing suspicious on the soldering.
This might need an RMA.
neil0174
Wed Jul 04, 2012 7:16 pm
Thanks dom. As suspected it didn't make any difference.
I'll find an unsuspecting volunteer over the weekend and try it out on another TV and cable combination ;-)
neil0174
Thu Jul 12, 2012 7:35 pm
Well I tried the Pi on a friend's TV (also using my cable) and it all worked fine!
So the hardware is obviously ok, but I'm now stuck (again).
Steptoansson
Thu Jul 12, 2012 8:14 pm
I'm also having trouble with my hdmi output to a Sony KDL32... tv. There's some more detail in the Using the Raspberry pi and top thread 'basic set up and usage'. Looks a bit tricky though :shock:
