My pi is running in a case. The connectors plugs completely in both sockets (at pi and monitor/adapter) - there is about 1mm space.
The same cable (incl. adapter) works with the connection between my desktop computer and the monitor (mentioned below as monitor 1).
I tried it with a TV (pi with openelec 4.2.1/5.0.0) and monitor (monitor 2), but without any config changes.
I just tried some configurations - not all possible - see first post (all params were changed together). I'm using Raspbian, not NOOBS.
Monitor 1 (LG Flatron E2411):
# tvservice -m DMT
Group DMT has 11 modes:
mode 4: 640x480 @ 60Hz 4:3, clock:25MHz progressive
mode 6: 640x480 @ 75Hz 4:3, clock:31MHz progressive
mode 9: 800x600 @ 60Hz 4:3, clock:40MHz progressive
mode 11: 800x600 @ 75Hz 4:3, clock:49MHz progressive
mode 16: 1024x768 @ 60Hz 4:3, clock:65MHz progressive
mode 18: 1024x768 @ 75Hz 4:3, clock:78MHz progressive
mode 21: 1152x864 @ 75Hz 4:3, clock:108MHz progressive
mode 35: 1280x1024 @ 60Hz 5:4, clock:108MHz progressive
mode 36: 1280x1024 @ 75Hz 5:4, clock:135MHz progressive
(prefer) mode 58: 1680x1050 @ 60Hz 16:10, clock:146MHz progressive
mode 82: 1920x1080 @ 60Hz 16:9, clock:148MHz progressive
Monitor 2 (LG Flatron L1970HR):
# tvservice -m DMT
Group DMT has 7 modes:
(prefer) mode 35: 1280x1024 @ 60Hz 5:4, clock:108MHz progressive
