wyattwong
Cannot install gcc-multilib
Sat Feb 21, 2015 4:10 pm
I typed the following command to install gcc-multilib:
sudo apt-get install gcc-multilib
but I got the following error message:
Reading package lists... Done
Building dependency tree
Package gcc-multilib is not available, but is referred to by another package.
This may mean that the package is missing, has been obsoleted, or
is only available from another source
E: Package 'gcc-multilib' has no installation candidate
How do I fix it ?
plugwash
Re: Cannot install gcc-multilib
Sat Feb 21, 2015 4:20 pm
gcc-multilib does not exist in either raspbian or any arm port of Debian though it looks like it does exist in arm ports of ubuntu.
What is the bigger picture here? why do you think you need gcc-multilib?
wyattwong
Sun Feb 22, 2015 2:56 pm
plugwash wrote:gcc-multilib does not exist in either raspbian or any arm port of Debian though it looks like it does exist in arm ports of ubuntu.
Well, never mind then.
taf2
Fri May 08, 2015 8:20 pm
We need gcc-multilib and g++-multilib as per the electron.atom.io dependency tree...
see: https://github.com/atom/electron/blob/m ... s-linux.md
nixomose
Wed Jul 06, 2016 12:41 am
Surely there must be a way to build the package from source, no? If there were some intrepid youngster with the interest to do it, where would they start?
m1f2c3
Mon Sep 25, 2017 10:31 am
Hi,I have the same question(install gcc-multilib on raspberry).what your meaning is that raspberry won't install gcc-multilib from any sources about raspbian?
My English is poor,sorry.
seanspotatobusiness
Tue Oct 10, 2017 4:49 pm
I tried to follow the instructions here: https://www.electron.build/multi-platform-build
To build app in 32 bit from a machine with 64 bit:
sudo apt-get install --no-install-recommends -y gcc-multilib g++-multilib
[email protected]:~/Teleprompter 32-bit/Teleprompter-Electron $ sudo apt-get install --no-install-recommends -y gcc-multilib g++-multilib
E: Unable to locate package g++-multilib
E: Couldn't find any package by regex 'g++-multilib'
I'm guessing this won't ever be fixed
Raspberry Pi 3 B and B+
PRETTY_NAME="Raspbian GNU/Linux 9 (stretch)"
NAME="Raspbian GNU/Linux"
VERSION_ID="9"
VERSION="9 (stretch)"
