RPI 2, LIRC -> Sending KEYS
Posted: Wed Feb 18, 2015 5:38 pm
by fire3k
Ok, i am quite new to thhis forum (also to PI GPIO usage) but i think i tried everything i've found to fix the Problem ....
As described, i have a PI 2, Latest Updates und such are installed, Lirc is running (Recive works, send not)
I have build a few IR Transmitters to test different way's, but i cannot get Lirc to send Remote codes.
Here's my conf:
config.txt
# Uncomment this to enable the lirc-rpi module
device_tree_overlay=lirc-rpi
device_tree_param=gpio_out_pin=17
device_tree_param=gpio_in_pin=18
device_tree_param=gpio_in_pull=down
as said before, recive is not a problem, only sending with IR doesn't work, when i send some recorded
IR Signal the control LED only flickers very low.
I searched the forums, the net a few day's but i cannot find a soloution, has anyone here running LIRC
on tje RPI 2 with Reciving AND sending?
thx
Re: RPI 2, LIRC -> Sending KEYS
Posted: Wed Feb 18, 2015 8:34 pm
by elmicha
You are not alone!
Here is another thread where a few people (including me) have the same problem: receiving works, sending does not. It worked on the RPi1, and it still works on the RPi1 with the latest kernel and the device tree.
Posted: Wed Feb 18, 2015 9:04 pm
by theceej
fire3k wrote:Ok, i am quite new to thhis forum (also to PI GPIO usage) but i think i tried everything i've found to fix the Problem ....
Here's my conf:
config.txt
thx
This has been fixed with the latest kernel from rpi-update!
Posted: Wed Feb 18, 2015 9:47 pm
by elmicha
Ah yes, thank you, you are correct, now it works!
The output of "uname -a" now has "3.18.7-v7+ #756".
Posted: Wed Feb 18, 2015 11:19 pm
by fire3k
wow, thx for the hint, i think the new kernel is fresh :)
anyways, it works now .....
thank you
