Nexter92
Crash every day (photo with error code)
Thu Aug 05, 2021 8:00 am
Hello guy, i have my personal raspberry pi 4 and I work great BUT my friend have one to and have crash every day with the exactly same configuration of me or other people, same program, same network, same stuff :(
When the pi crash, impossible to ssh, impossible to reboot without unplug the pi4 :(
Pi4 4gb of ram
USB boot to SSD with same adaptor I have and I know allot of people have
Official power supply
a heat sink
I have try to change > Ethernet cable, heat sink, power supply, adaptor USB to SSD and nothing work :(
I have try to change / reinstall allot of os, Ubuntu server 20.10 (maybe ten reinstallation), raspberry pi lite (4 times), raspberry pi 64bit lite (2 times)
I have plug the HDMI to see the message when the pi crash and I have this message (raspberry pi 64bit lite)
I have try to add reboot when kernel panic and the pi don't want to reboot :(
Oh and yes I have update the bootloader :)
drgeoff
Re: Crash every day (photo with error code)
Thu Aug 05, 2021 9:22 am
Looks like a problem with sda2. Try swapping that with another SSD.
Quis custodiet ipsos custodes?
Nexter92
Thu Aug 05, 2021 11:27 am
Ok men I will try that, but it's weird no ? The pi boot but after some hours crash :(
FTrevorGowen
Thu Aug 05, 2021 1:08 pm
@Nextor92,
Although you state:
"USB boot to SSD with same adaptor I have and I know allot of people have" in your O.P., have you confirmed that both adapters actually use the same chipset. At least one "brand" is known to use different chipsets from time-to-time:-
Compare http://www.cpmspectrepi.uk/raspberry_pi ... SATA_Cable
with http://www.cpmspectrepi.uk/raspberry_pi ... _Cable.232
for example.
Trev.
Still running Raspbian Jessie or Stretch on some older Pi's (an A, B1, 2xB2, B+, P2B, 3xP0, P0W, 2xP3A+, P3B, B+, and a A+) but Buster on the P3B+, P4B's & P400. See: https://www.cpmspectrepi.uk/raspberry_pi/raspiidx.htm
Nexter92
Thu Aug 05, 2021 4:36 pm
@Nextor92,
Although you state:
for example.
Trev.
It's the same brand and chipset :(
And I have change the adaptor it's not that I think, I am going to try a new SSD :(
