java_c
Running out of available space
Tue Aug 03, 2021 7:22 pm
Hi, two months ago I upgraded my raspberry from a 16GB to a 32 GB card.
After copying the card I expanded the filesystem via raspi-config "expand Filesystem".
This work's fine and I hat the available space of about 15GB.
Now two months later I ran again in the situation that I run out of space. I already searched for a solution but couldn't found a solution.
Please find here some details:
Available DiskSpace
sudo df
Dateisystem          1K-Blöcke   Benutzt  Verfügbar Verw% Eingehängt auf
/dev/root             30613684  30544556          0  100% /
devtmpfs                469544         0     469544    0% /dev
tmpfs                   474152         0     474152    0% /dev/shm
tmpfs                   474152     12292     461860    3% /run
tmpfs                     5120         8       5112    1% /run/lock
tmpfs                   474152         0     474152    0% /sys/fs/cgroup
none                      5120       180       4940    4% /var/log
/dev/mmcblk0p1           42131     22856      19275   55% /boot
//192.168.2.30/home 1917962728 813937064 1103906880   43% /NAS/pi
tmpfs                    94828         0      94828    0% /run/user/1000
Available Inodes
sudo df -i
Dateisystem            Inodes IBenutzt     IFrei IUse% Eingehängt auf
/dev/root             1877344   131868   1745476    8% /
devtmpfs               117386      390    116996    1% /dev
tmpfs                  118538        1    118537    1% /dev/shm
tmpfs                  118538      446    118092    1% /run
tmpfs                  118538        4    118534    1% /run/lock
tmpfs                  118538       12    118526    1% /sys/fs/cgroup
none                   118538       12    118526    1% /var/log
/dev/mmcblk0p1              0        0         0     - /boot
//192.168.2.30/home 121798656   595318 121203338    1% /NAS/pi
tmpfs                  118538       11    118527    1% /run/user/1000
sudo fdisk -l
Disk /dev/mmcblk0: 29,7 GiB, 31914983424 bytes, 62333952 sectors
Units: sectors of 1 * 512 = 512 bytes
Sector size (logical/physical): 512 bytes / 512 bytes
I/O size (minimum/optimal): 512 bytes / 512 bytes
Disklabel type: dos
Disk identifier: 0xc92dee4d
Device         Boot Start      End  Sectors  Size Id Type
/dev/mmcblk0p1       8192    93802    85611 41,8M  c W95 FAT32 (LBA)
/dev/mmcblk0p2      98304 62333951 62235648 29,7G 83 Linux
sudo ncdu
  118,9 GiB [##########] /NAS
    1,7 GiB [          ] /usr
  368,2 MiB [          ] /opt
  201,0 MiB [          ] /var
  200,0 MiB [          ] /home
  199,6 MiB [          ] /root
  191,2 MiB [          ] /lib
   22,3 MiB [          ] /boot
   12,0 MiB [          ] /run
    7,4 MiB [          ] /sbin
    6,7 MiB [          ] /bin
    4,0 MiB [          ] /etc
   32,0 KiB [          ] /tmp
e  16,0 KiB [          ] /lost+found
    8,0 KiB [          ] /data
e   4,0 KiB [          ] /srv
e   4,0 KiB [          ] /mnt
e   4,0 KiB [          ] /media
e   4,0 KiB [          ] /Synology
    0,0   B [          ] /sys
.   0,0   B [          ] /proc
    0,0   B [          ] /dev
Re: Running out of available space
Wed Aug 04, 2021 8:44 am
You might have some massive log files taking up space?
Check /var/log
Also, there is a disk usage utility you can install, that will tell you what is using up space where, which might help track things down.
Working in the Applications Team.
RaTTuS
Contact: Twitter YouTube
Wed Aug 04, 2021 8:53 am
du -h / | sort -nr | less
but maybe you have filled up
/NAS/pi
by stuffing stuff there before it is loaded from the network
unount that drive and look in there
Covfefe
cleverca22
Wed Aug 04, 2021 10:05 am
first tip, always use "ncdu -x", so it wont count space from a remote machine (your nas)
2nd tip along the lines of what RaTTuS said, temporarily `umount /NAS/pi` so ncdu can look behind that curtain, your likely writing stuff when it isnt mounted
jbudd
Wed Aug 04, 2021 10:09 am
The only time my Pies have run out of space it was huge logfiles in /var/log.
The du command will help track down where your disk is filling up
sudo du -sm /* 2>/dev/null | sort -V shows the disk usage in MB of each directory in /
0       /bin
0       /lib
0       /proc
0       /sbin
0       /sys
1       /lost+found
1       /media
1       /mnt
1       /srv
1       /tmp
2       /dev
9       /run
22      /etc
47      /opt
49      /boot
49      /boot.bak
58      /root
750     /var
2561    /home
6404    /usr
Followed by (eg) sudo du -sm /var/* 2>/dev/null | sort -V
java_c
Mon Aug 09, 2021 8:19 am
First of all thanks for your feedback:
- I disabled cifs mounting of network folder in /etc/fstab
//192.168.2.30/home /NAS/pi cifs username=*****,password=*****,workgroup=workgroup,vers=1.0,users,auto,user_xattr 0 0
I found that two backup files of my monthly backup were stored directly on the ssd card and not on the network folder /NAS/pi.
Deleting these files solved my problem.
Is there a way to protect such behaviour?
Here is the script I run once a month.
BACKUP_PATH="/NAS/pi"
BACKUP_NAME="RaspberryPiBackup"
dd if=/dev/mmcblk0 of=${BACKUP_PATH}/${BACKUP_NAME}-$(date +%Y%m%d-%H%M%S).img bs=1MB
Mon Aug 09, 2021 8:26 am
A simple check could be:
if ! mountpoint -q ${BACKUP_PATH}
then
  echo "Backup drive is not mounted!"
  exit 1
fi
Unreadable squiggle
thagrol
Mon Aug 09, 2021 11:12 am
then
  exit 1
fi
And/or unmount the NAS then
chmod a-w /NAS/pi
That'll prevent anyone/anything writing when the NAS is not mounted but the errors will be more obscure.
Though frankly, unless your backup process is running as root I'm surprised you can write to the NAS with that fstab entry. You don't set either local user/group or local permissions so will be getting the default (root:root rwxr-xr-x)
And why have you included the users mount option? Do you really want any random user on your system to be able to mount and unmout the NAS?
I'm a volunteer. Take me for granted or abuse my support and I will walk away
All advice given is based on my experience. it worked for me, it may not work for you.
Need help? https://github.com/thagrol/Guides
cleverca22
Mon Aug 09, 2021 1:14 pm
my choice, is to `chmod 0 /NAS/pi` while its not mounted, so nobody has permission to do anything
then do what others have said, and test that its actually mounted, the chmod is just a safety net, so it will fail if you dont test right
java_c
Tue Aug 10, 2021 6:14 am
Thanks to all of you, I could handle the issue with the provided script. I included this in my monthly backup procedure.
Also many thanks for the hint regarding users in cifs.
