Janick_Spielmann
No able to upgrade new flashed Pi
Sun Aug 01, 2021 11:06 am
I have a problem updating my newly flashed Pi4
I did
 sudo apt update
And it worked fine. (37 packages can be upgraded...)
So I did
sudo apt upgrade
It started out fine
Now it is stuck at 44% not doing anything.
So I thought that I might have made a mistake while flashing or something else went wrong.
I flashed the SD card again downloaded the Lite OS (I don't need Desktop as I am connected via SSH) and now it got stuck at 48%
I can't figure out what the problem is. The LED code (7 short flashes) tells me "Kernel image not found". How can this happen while updating? This is not my first time using Raspberry Pi and I am sure that I did nothing wrong while flashing the SD card and I tried using another SD card getting the same result.
Re: No able to upgrade new flashed Pi
Sun Aug 01, 2021 11:44 am
I did
 sudo apt update
So I did
sudo apt upgrade
It started out fine
full-upgrade recommended over upgrade:
https://www.raspberrypi.org/documentati ... pdating.md
Take what I advise as advice not the utopian holy grail, and it is gratis !!
Janick_Spielmann
Sun Aug 01, 2021 3:02 pm
Still dose not work... stuck on 48%
pidd
Sun Aug 01, 2021 3:29 pm
If its a kernel update on a slow SD card there is a very slow section in the the upgrade, got me a bit worried on a Pi0 the other day.
