Lipown
Cannot load desktop after last update - *ERROR* Failed to allocate from CMA
Sun Aug 01, 2021 7:44 am
Hi, I am getting this error in Dmesg and the desktop wont start :( I do not know what to fix it.
[  +0.109406] [drm:vc4_bo_create [vc4]] *ERROR* Failed to allocate from CMA:
[  +0.000021] vc4-drm gpu: [drm]                           dumb:   4052kb BOs (1        )
rpdom
Re: Cannot load desktop after last update - *ERROR* Failed to allocate from CMA
Sun Aug 01, 2021 8:07 am
How much memory do you have assigned to the GPU? It should be somewhere between 64MB and 256MB. Having higher than that can cause problems. I believe there was a change to how memory is used in a recent update.
Unreadable squiggle
Lipown
Sun Aug 01, 2021 8:39 am
Since almost two years ago I had set it to 512. 256 solved the problem. I hope it is enough. Many thanks!
