pettefar
SD Copy Fails While Cloning SD to SSD
Tue Jul 27, 2021 8:35 pm
When trying to clone my RP4-8GB SD card to an SSD I keep getting "Drives changed - copy aborted" and the system hangs and has to be power-cycled.
Any ideas?
(I tried using rsync and that also hung my system!)
Nick
Dublin
epoch1970
Re: SD Copy Fails While Cloning SD to SSD
Tue Jul 27, 2021 8:37 pm
Power supply
FTrevorGowen
Tue Jul 27, 2021 9:19 pm
Power supply
+1 and/or maybe, assuming a USB-to-SATA SSD adapter is in use, one with an unsuitable (for linux) chipset.
@pettefar, can you post the outputs of
lsusb
and
lsusb -t
(within code tags, as above)
Trev.
Still running Raspbian Jessie or Stretch on some older Pi's (an A, B1, 2xB2, B+, P2B, 3xP0, P0W, 2xP3A+, P3B, B+, and a A+) but Buster on the P3B+, P4B's & P400. See: https://www.cpmspectrepi.uk/raspberry_pi/raspiidx.htm
pettefar
Wed Jul 28, 2021 7:41 pm
root@sauce:~# lsusb
Bus 002 Device 002: ID 152d:1561 JMicron Technology Corp. / JMicron USA Technology Corp. JMS561U two ports SATA 6Gb/s bridge
Bus 002 Device 001: ID 1d6b:0003 Linux Foundation 3.0 root hub
Bus 001 Device 006: ID 1a86:7523 QinHeng Electronics HL-340 USB-Serial adapter
Bus 001 Device 005: ID 0461:4d03 Primax Electronics, Ltd Kensington Mouse-in-a-box
Bus 001 Device 004: ID 04d9:0006 Holtek Semiconductor, Inc.
Bus 001 Device 003: ID 05e3:0610 Genesys Logic, Inc. 4-port hub
Bus 001 Device 002: ID 2109:3431 VIA Labs, Inc. Hub
root@sauce:~#
root@sauce:~# lsusb -t
/:  Bus 02.Port 1: Dev 1, Class=root_hub, Driver=xhci_hcd/4p, 5000M
    |__ Port 2: Dev 2, If 0, Class=Mass Storage, Driver=uas, 5000M
/:  Bus 01.Port 1: Dev 1, Class=root_hub, Driver=xhci_hcd/1p, 480M
    |__ Port 1: Dev 2, If 0, Class=Hub, Driver=hub/4p, 480M
        |__ Port 4: Dev 3, If 0, Class=Hub, Driver=hub/4p, 480M
            |__ Port 1: Dev 4, If 0, Class=Human Interface Device, Driver=usbhid, 1.5M
            |__ Port 1: Dev 4, If 1, Class=Human Interface Device, Driver=usbhid, 1.5M
            |__ Port 2: Dev 5, If 0, Class=Human Interface Device, Driver=usbhid, 1.5M
            |__ Port 4: Dev 6, If 0, Class=Vendor Specific Class, Driver=ch341, 12M
root@sauce:~#
Nick
Dublin
pettefar
Wed Jul 28, 2021 7:48 pm
I wrote a new image on it using the Raspberry Pi Imager on my Mac and when I booted it up it said "Resizing disk" and then the screen blanked and nothing more happened apart from the drive's activity light flashing. I guess this drive (Sabrent) will never work.
Nick
Dublin
pidd
Wed Jul 28, 2021 8:30 pm
What model is the Sabrent?
FTrevorGowen
Wed Jul 28, 2021 10:03 pm
root@sauce:~# lsusb
root@sauce:~#
root@sauce:~#
Unfortunately (some) JMicron chipsets do not play well with Linux (although applying a quirk** may help, but reduce transfer rates).
Trev.
** See this thread: viewtopic.php?f=28&t=245931
pettefar
Wed Jul 28, 2021 10:52 pm
EC-UASP
Nick
Dublin
pettefar
Wed Jul 28, 2021 10:59 pm
Can anyone recommend a currently available SSD drive that is reasonably priced?
Nick
Dublin
pidd
Thu Jul 29, 2021 12:04 am
Kingston A400 SSDs, just about as cheap as they get, speed is just about as fast as anything can be on a Pi, ultra-reliable, very low power (I drive two off one Pi4). I have around eight of them, four run 24/7 with a lot more than average throughput, two were low-usage second-hand.
If you are looking for USB3-sata adapter I recommend Ugreen. There are possibly cheaper adapters but Ugreen always have the Asmedia chipset and not Jmicron.
pettefar
Thu Jul 29, 2021 9:07 pm
OK, thanks very much for the recommendations. I'll see how I fare with them.
Nick
Dublin
pettefar
Sun Aug 01, 2021 6:19 pm
Well, I finally got it working with the recommended hardware.
I tried the SD card cloning from the source Raspberry pi 4 8GB but it kept rebooting the Pi around the 9/10 copy partition 2 leg. After five attempts I gave up and installed a clean copy of Raspberry Pi OS image on it and copied the relevant details over from the original SD card.
I'll see if I can use the Sabrent as a backup device.
Nick
Dublin
