theio
Raspberry Pi 64-bit wiped my filesystem - how to fix? (RESOLVED)
Wed Jul 28, 2021 8:44 am
As the title suggests, I have a problem. If this is the wrong forum for raising it, let me know.
I have a Raspberry Pi 4, which had been running Raspberry Pi OS 32-bit (installed via the Imager) without any trouble, but I wanted to try the 64-bit version as well. So I got a PNY Performance Plus 64GB microSD card, downloaded the Raspberry Pi OS 64-bit from here (https://downloads.raspberrypi.org/raspi ... 021-05-28/), installed it to the card, set up the Pi, process worked through fine, and I had a nice new fresh 64-bit OS.
Then I turned it off and on again.
When it turned back on, it looked like this:
very no filesystem.jpg (55.97 KiB) Viewed 333 times
Turned it off, put the SD card in my PC to see what had happened. Turned out that it was both write-protected and missing a filesystem. I can't remove write protection without reformatting it. I can't reformat the filesystem without removing write protection.
What should I do? Is it a problem with the OS? The board? The SD card itself? I am massively confused at what's happened it, and yet it's happened.
EDIT: Bought a new Sandisk SD card, and that's managed to reboot without problem. Still keeping an eye on it, but for now it works.
jahboater
Re: Raspberry Pi 64-bit wiped my filesystem - how to fix?
Wed Jul 28, 2021 8:50 am
I think your SD card as died.
Nothing to do with the 64-bit OS.
Try a new Sandisk A1 class card (say 32 or 64 GB), they are cheap, fast, and reliable.
theio
Wed Jul 28, 2021 8:55 am
I considered the card; I'm just confused given that I've got an identical card on a Pi 3B with 32-bit and that's survived several reboots, whereas a fresh card with a 64-bit has gone kaput basically instantly.
Wed Jul 28, 2021 8:56 am
https://www.jeffgeerling.com/blog/2019/ ... rison-2019
Take what I advise as advice not the utopian holy grail, and it is gratis !!
jahboater
Wed Jul 28, 2021 10:00 am
If this was a brand new card, it must have been faulty. Perhaps return it to the vendor.
"Installing" the Raspberry Pi OS, is in fact a simple, single, file copy.
It is the same for the 32 and 64 bit OS's.
FTrevorGowen
Wed Jul 28, 2021 12:28 pm
FWIW, I've passed the card's CID, as reported in the bootloader diagnostics screenshot, through my cid-decoder tool with somewhat strange results:
trevor@raspiP400gPiOS64:~/usdcard_tools-0.0 $ ./src/cid_decoder -rawCID 009f5449202020202000000000000147 -LX -tag theio
cid_decoder.c Version 0.01 {Exp}, [12/06/2019], (c) F_Trevor_Gowen
		<--| Package usdcard_tools_0.0 |-->
<cid_decoder.arg>	fopen: No such file or directory
cid_decoder.arg not found
Initialising cid ...
Logging to ... raspiP400gPiOS64_theio_cid.log
grawcid = 009f5449202020202000000000000147
raspiP400gPiOS64 sdcard cid status:
RAWCID 009f5449202020202000000000000147
MID    0x00
OID    0x9f54 (�T)
PNM    0x4920202020 (I    )
PRV    0x20 (2.0)
PSN    0x00000000
RSVD   0x0
MDT    0x001 (1/2000)
CRC+1  0x47
Although it's possible that there's an extra or missing byte given that "5449" --> TI is, IIRC, a valid OID (for Texas Instruments?) IIRC
FWIW, compare the above with a working card that was in use with the P400 I'm posting from before I moved to USB (SSD) boot:
trevor@raspiP400gPiOS64:~/usdcard_tools-0.0 $ cat raspiP400gPiOS64_cid.log
RAWCID 03534453443030383000000000013201
MID    0x03
OID    0x5344 (SD)
PNM    0x5344303038 (SD008)
PRV    0x30 (3.0)
PSN    0x00000000
RSVD   0x0
MDT    0x132 (2/2019)
CRC+1  0x01
Trev.
Still running Raspbian Jessie or Stretch on some older Pi's (an A, B1, 2xB2, B+, P2B, 3xP0, P0W, 2xP3A+, P3B, B+, and a A+) but Buster on the P3B+, P4B's & P400. See: https://www.cpmspectrepi.uk/raspberry_pi/raspiidx.htm
kerry_s
Wed Jul 28, 2021 12:53 pm
on mine, sometimes when it wont boot, i would pull the sdcard out clean the sd card pins(gold part on sd card) then put back in & try again.
theio
Re: Raspberry Pi 64-bit wiped my filesystem - how to fix? (RESOLVED)
Wed Jul 28, 2021 1:07 pm
wildfire
Wed Jul 28, 2021 2:16 pm
Virtually everything is stored on the card (not on the Pi), so simply transferring one card for another would not cause a problem, except if the replacement...
1) does not have a suitable (up to date) operating system.
2) has been corrupted (eg by not shutting down/unmounted correctly) and just pulled out.
3) has simply failed, possibly due to being a counterfeit.
E8 85 A2 40 C9 40 81 94 40 81 95 40 89 84 89 96 A3
Still NF Shirls
