Splint
Onboard bluetooth comms between RPi 3s
Thu Jun 17, 2021 7:42 am
I've been following this guide https://www.reddit.com/r/raspberry_pi/c ... th_serial/ but I got to step 4 and entered:
sudo nano /etc/systemd/system/dbus-org.bluez.service
the response was
Invalid command in menu main: sudo
I'm confident there are no errors in the command. Anyone know what's going on here?
Re: Onboard bluetooth comms between RPi 3s
Thu Jun 17, 2021 7:58 am
You need to exit from the "[bluetooth]#" prompt before you can type that command. Just "exit" or "quit" or pressing Ctrl and D should do it.
Unreadable squiggle
Splint
Thu Jun 17, 2021 8:05 am
Thank you :)
Splint
Sat Jun 19, 2021 6:24 am
Things have gone pretty well up to the last step where the address is changed in the rfcomm-client.py file is changed.
The default code is:
addr = None
which I changed to:
addr = B8:27:EB:5E:18:0F
But when I try and run the code it returns a syntax error with the arrow pointing at the first colon. Any idea why this is the case and hoe to resolve it?
There is also mention in the reddit guide of "it's a string so use "ADDRESS"", I'm not clear on what this means.
Thanks.
RonR
Sat Jun 19, 2021 7:04 am
addr = None
which I changed to:
Have you tried using "B8:27:EB:5E:18:0F" (with quotes) or "B827EB5E180F" (without colons and with/without quotes)?
Sat Jun 19, 2021 7:09 am
addr = None
which I changed to:
Thanks.
That line should be:
addr = "B8:27:EB:5E:18:0F"
It's a string, so it needs to be in quotes.
Unreadable squiggle
Splint
Sat Jun 19, 2021 1:35 pm
Thank you, that is now working.
One further question, what I would like to do is to use one RPi to monitor a micro switch which when triggered can message the other RPi wirelessly to start it's picamera to record video for a period of time.
For my limited experience I suspect the easiest way to do this would be to have the switch monitoring pi write a date/time stamp to a file a and have the camera pi syncing the file and looking for the date time as the trigger to record.
Any thoughts on how I would go about this or whether it's the best way of doing it?
Thanks again.
B.Goode
Sat Jun 19, 2021 2:10 pm
Thanks again.
gpiozero. Remote GPIO
https://gpiozero.readthedocs.io/en/stab ... _gpio.html
That certainly works over a WiFI connection: I have no experience of using it via Bluetooth.
Splint
Sat Jun 19, 2021 5:28 pm
Perfect. Thank you.
