mattwelter
Pi 4 – /dev/root 100% full can't do anything
Fri Jun 18, 2021 7:10 am
This is my first time posting on this forum.
/dev/root is 100% full
64gb SD card
Raspberry Pi 4 running Debian
I have a few guesses but not sure how to go about fixing it.
Other than running 4 Twitter bots using Python (takes up super super little space), I run 5-10 Selenium Chromedriver instances a day on the pi for automating a "few" online processes. That's the only things I use the pi for. So, I was assuming it had to do with Chromedriver's cache, or log, or something. But I cleared the Chromedriver cache and /dev/root went from 100% to 99%, so I'm not sure what's taking up all this space.
Honestly not too sure what else to provide. This has never been a problem. Maybe I just never checked storage as much as I actually should have.
topguy
Re: Pi 4 – /dev/root 100% full can't do anything
Fri Jun 18, 2021 9:18 am
if you add "-h" to your "df" ( and "du" ) commands it will print more readable size values ( GB and MB ).
How was your SD card created/imaged ?
I guess...
sudo fdisk -l /dev/mmcblk0
should list the partitions on the SD card..
cleverca22
Fri Jun 18, 2021 10:35 am
the "df -m" in the screenshot just forces it to always be in mb, it looks like a 56gig rootfs, within the expected rounding errors due to 1000 vs 1024
my advise would be to run "ncdu /" and then browse around to see where all of the used space has gone to
jahboater
Fri Jun 18, 2021 10:52 am
You learn something new all the time! Thanks
I have been using
du <dir> | sort -rn | .....
for several decades, but this ncurses version is much better.
swampdog
Fri Jun 18, 2021 11:03 am
Assuming you can't install any more packages..
$ sudo du -ks /* | sort -n -k1
..biggest number (ie: sizes) toward the bottom. That identifies the folders to pay most attention to first then drill down manually. eg:
foo@pi20:~ $ sudo du -ks /* | sort -n -k1
du: cannot access '/proc/1852/task/1852/fd/4': No such file or directory
du: cannot access '/proc/1852/task/1852/fdinfo/4': No such file or directory
du: cannot access '/proc/1852/fd/3': No such file or directory
du: cannot access '/proc/1852/fdinfo/3': No such file or directory
du: cannot access '/run/user/1000/gvfs': Permission denied
0	/bin
0	/dev
0	/lib
0	/proc
0	/sbin
0	/sys
4	/nohup.out
4	/srv
12	/opt
16	/lost+found
28	/mnt
56	/root
64	/tmp
6488	/etc
8860	/run
30056	/boot
500428	/var
1020580	/wrk
3524356	/home
5767548	/usr
10023164	/media
foo@pi20:~ $ sudo du -ks /wrk/* | sort -n -k1
0	/wrk/rcl.sh.lck
4	/wrk/c.cc
4	/wrk/dns.pub
4	/wrk/finit.log
4	/wrk/finit.sh
4	/wrk/fipaddr.log
4	/wrk/fipaddr.sh
4	/wrk/rcl.log
4	/wrk/rcl.sh
4	/wrk/rinit.log
4	/wrk/rinit.sh
4	/wrk/sdu.pub
4	/wrk/wibble
4	/wrk/wotzit
4	/wrk/z
4	/wrk/z.c
12	/wrk/c
12	/wrk/lo.tar
12	/wrk/XPT2046.tar
24	/wrk/z-sm.000
24	/wrk/z-sm.001
24	/wrk/z-sm.002
24	/wrk/z-sm.003
24	/wrk/z-sm.004
132	/wrk/sd.tar
5732	/wrk/barrier.tar
41648	/wrk/nomachine_7.4.1_1_armhf.deb
47520	/wrk/wrk.tar
925328	/wrk/TT
foo@pi20:~ $ sudo du -ks /wrk/TT/* | sort -n -k1
60696	/wrk/TT/Urho3D-1.7.1-Source.tar.gz
152444	/wrk/TT/Urho3D-1.7.1
712184	/wrk/TT/obj
..looks like I left /wrk/TT/obj/ lying about so that's a candidate for removal.
cleverca22
Fri Jun 18, 2021 11:06 am
0	/bin
0	/dev
0	/lib
0	/proc
0	/sbin
0	/sys
4	/nohup.out
4	/srv
12	/opt
16	/lost+found
28	/mnt
56	/root
64	/tmp
6488	/etc
8860	/run
30056	/boot
500428	/var
1020580	/wrk
3524356	/home
5767548	/usr
10023164	/media
0	/wrk/rcl.sh.lck
4	/wrk/c.cc
4	/wrk/dns.pub
4	/wrk/finit.log
4	/wrk/finit.sh
4	/wrk/fipaddr.log
4	/wrk/fipaddr.sh
4	/wrk/rcl.log
4	/wrk/rcl.sh
4	/wrk/rinit.log
4	/wrk/rinit.sh
4	/wrk/sdu.pub
4	/wrk/wibble
4	/wrk/wotzit
4	/wrk/z
4	/wrk/z.c
12	/wrk/c
12	/wrk/lo.tar
12	/wrk/XPT2046.tar
24	/wrk/z-sm.000
24	/wrk/z-sm.001
24	/wrk/z-sm.002
24	/wrk/z-sm.003
24	/wrk/z-sm.004
132	/wrk/sd.tar
47520	/wrk/wrk.tar
925328	/wrk/TT
712184	/wrk/TT/obj
you want to add a -x to that du command
that will stop it from trying to traverse /proc and /dev
you can also use du -h | sort -h, to make it human readable, and still sort right
but from the screenshot, the OP has 600mb free now, so plenty of room to install ncdu, which is far more usable
jahboater
Fri Jun 18, 2021 12:27 pm
No need to install ncdu on Pi OS.
It is included by default, even on the Lite version.
With ncdu, drill down is just pressing <return> when the cursor is over a directory.
cleverca22
Fri Jun 18, 2021 12:29 pm
left/right arrows also work, so you can drill down very quickly with just the arrow keys, and back out if you go down a wrong path
