subtlenv
33 Watt Smartphone Charger to Power up my RasPI 3B+. I am concerned !!
Wed Jun 16, 2021 2:29 pm
Let me provide a little background for my title.
One morning I woke up and the Raspberry PI was dead, well not the PI but yeah. There were some thunderstorms previous night. And I felt that it might have fried my PI. But that wasn't the case. My power adapter that came in the Raspberry PI Kit was dead, I confirmed it.
Fast forward a few days. I tried to use my 2AMP rated 5v smartphone adapter to power it up. But the lights went haywire still I could technically use my pi but the lights would come and go like it's about to go out. I pulled the plug and didn't use it again.
Fast forward more few days, the present day. I got a charger that had a 3AMP @ 6v and 1.5AMP @ 12v rating. So I've been using it to power my PI up and everything looks good except my mental state.
I know I should get a proper adapter but due to covid and stuffs I cannot get anything to buy. Also, I am using PI as a bridge so I'm desperate to keep using it.
My question is: Will it affect my PI ? And should I continue using it ? And why in the world does a smartphone charger have multiple output ratings ? And most importantly how does it know when to supply what amount ?
wildfire
Re: 33 Watt Smartphone Charger to Power up my RasPI 3B+. I am concerned !!
Wed Jun 16, 2021 2:37 pm
It's been repeated often on here "a charger is not a PSU".
I'd say you've been lucky so far but feeding 6V to your Pi won't end well. Get a PSU as soon as you can.
E8 85 A2 40 C9 40 81 94 40 81 95 40 89 84 89 96 A3
Still NF Shirls
trejan
Wed Jun 16, 2021 4:31 pm
They're not feeding it 6V. They have a charger with QC or similar that can negotiate for a higher voltage. The non-negotiated voltage is still 5V.
trejan
Wed Jun 16, 2021 4:37 pm
No. The charger will output 5V unless told otherwise and the Pi has no ability to send the required signal for that.
If it is stable and you don't notice any issues like the low voltage lightning bolt then you're fine to continue using it. If you're unsure still or see odd behaviour then buy one of the official Pi PSUs.
The higher voltages allow more power to be delivered for faster charging of your phone/tablet/whatever.
The charger will have Quick Charge, USB-PD or another similar protocol. The charger will default to 5V as everything accepts that and then the device will signal to the charger that it accepts a higher voltage for faster charging.
wildfire
Wed Jun 16, 2021 4:41 pm
I understand that trejan, but chargers have not always negotiated properly, additionally we are not aware of how this charger is being connected to the PI 3B+
As far as I know negotiable chargers use a USB-C connector (I could be wrong) the 3B+ has no such connector. With lack of information I always err on the side of caution.
Still NF Shirls
trejan
Wed Jun 16, 2021 4:51 pm
You're being overly cautious. OP has stated that it isn't going to be easy for them to swap it. Why cause them unnecessary worry on the tiny chance that they've got a faulty charger? If it works and is stable then there is no reason to swap it.
There are many other standards like Quick Charge which support micro USB.
drgeoff
Wed Jun 16, 2021 8:55 pm
Is that 6v a typo or do you really mean it?
Quis custodiet ipsos custodes?
LTolledo
Wed Jun 16, 2021 9:34 pm
your mental state will return to normal until you use a proper power supply for your RPi....
no one can assure you if your mental state will recover or deteriorate further with your continued use of your charger
its your RPi
its your mental state
so.....
its your move....
Some people be like:
subtlenv
Thu Jun 17, 2021 12:49 pm
Wow! Thanks for putting that effort in providing an answering! :)
I finally understand how everything works now.
I normally SSH into my PI as it's a headless setup. But occasionally I do a xrdp ( vnc felt slow ).
Now that you've mentioned that "low voltage". I have noticed that it has a banner as shown below. Will it cause any harm to the PI ? I mean it's low power and not over power, how bad can it get ?
Screen Shot 2021-06-17 at 18.39.00.png (58.03 KiB) Viewed 189 times
subtlenv
Thu Jun 17, 2021 12:51 pm
It's not a typo. It has that written on the charger. The charger is for POCO X3.
subtlenv
Thu Jun 17, 2021 12:56 pm
Sure thanks, will get one as soon as I can. :)
subtlenv
Thu Jun 17, 2021 12:58 pm
its your RPi
so.....
its your move....
Hmmmmm...
Thu Jun 17, 2021 12:59 pm
It won't harm the Pi, but power supply issues can manifest in weird ways - unexpected crashes, SD card corruption, Ethernet dropouts etc
Working in the Application's Team.
