Nyrlem
Usb hub booting problem rpi400
Tue Jun 15, 2021 10:21 am
Hi, I installed ubuntu on external ssd and while connected directly to rpi400, it boots swiftly. But since i connected it to AXAGON HUE-S2BP 4x USB3.0 CHARGING hub, which i need for overclocking, it does not boot and calls timeout. Did someone solved something similar?
Re: Usb hub booting problem rpi400
Tue Jun 15, 2021 10:42 am
This is almost certainly a lack of power from the power supply.
Working in the Application's Team.
Nyrlem
Tue Jun 15, 2021 6:36 pm
Producer declares 5v/2a in every usb.. how much does raspberry pi 400 need? :)
Tue Jun 15, 2021 7:53 pm
https://www.raspberrypi.org/documentati ... ower-specs
https://www.raspberrypi.org/products/ty ... er-supply/
