Mayur7242
Pi 3b+ Is not working.
Mon Jun 14, 2021 3:59 pm
Hello ,
I have Pi 3b+. Bymistake I short 5V and Ground GPIO. It short onlt few mictro second and pi goes off. I am trying to boot up but it did not start. Only power led on. Green led (ACT) is not on. I tried 5-6 sd cards but not get solution.
davidcoton
Re: Pi 3b+ Is not working.
Mon Jun 14, 2021 4:07 pm
Disconnect the Pi. Wait 48hrs. Try again.
The Pi3B+ has a polyfuse on board to protect it, but it takes some time to recover after being triggered.
No guarantee, but a good chance of a full recovery.
klricks
Mon Jun 14, 2021 4:53 pm
The OP said the Power LED is working so the fuse is not blown.
In my experience once the fault condition is removed, a polyfuse will reset itself to a usable state within minutes. Certainly overnight should be plenty of time.......
davidcoton
Mon Jun 14, 2021 5:39 pm
Good point.
Is the Pi getting unusually hot? Or staying cold?
rpdom
Mon Jun 14, 2021 6:22 pm
If you have access to a voltemeter, check the voltage on the 3V3 pin of the GPIO header (pin 1). Use the outside of a USB or network socket for the other connection.
Unreadable squiggle
