ClipClopHorseyStomp
Newbie Having Trouble Mounting an SMB
Sun Jun 13, 2021 9:43 pm
New to the pi. I'm setting up a Plex server setup and I think I've got everything setup except I can't seem to get my SMB to mount.
my /etc/fstab rerads
proc            /proc           proc    defaults          0       0
PARTUUID=63900b8b-01  /boot           vfat    defaults          0       2
PARTUUID=63900b8b-02  /               ext4    defaults,noatime  0       1
# a swapfile is not a swap partition, no line here
#   use  dphys-swapfile swap[on|off]  for that
//192.168.0.1/NETWORK_DRIVE /home/pi/DRIVE/share cifs username=USERNAME,password=PASSWORD
but when I run sudo mount -a I get
mount error(22): Invalid argument
Refer to the mount.cifs(8) manual page (e.g. man mount.cifs)
RonR
Re: Newbie Having Trouble Mounting an SMB
Mon Jun 14, 2021 5:15 am
Try this:
//192.168.0.1/NETWORK_DRIVE /home/pi/DRIVE/share cifs username=USERNAME,password=PASSWORD,nofail,vers=1.0,rw,x-systemd.automount  0  0
LTolledo
Mon Jun 14, 2021 10:10 am
also don't forget to enable "wait for network" on the raspi-config...
Some people be like:
thagrol
Mon Jun 14, 2021 11:52 am
It's user= not username=.
See the output from
man mount.cifs
I'm a volunteer. Take me for granted or abuse my support and I will walk away
All advice given is based on my experience. it worked for me, it may not work for you.
Need help? https://github.com/thagrol/Guides
RonR
Mon Jun 14, 2021 5:30 pm
See the output from
man mount.cifs
username= and password= are legit.
From man mount.cifs (Raspberry Pi OS 32-bit/64-bit Buster/Bullseye):
username=arg|user=arg
password=arg|pass=arg
More specifically:
While some versions of the cifs kernel module accept user= as an abbreviation for this option, its use can confuse the standard
mount program into thinking that this is a non-superuser mount. It is therefore recommended to use the full username= option name.
RonR
Mon Jun 14, 2021 5:46 pm
Which is already enabled by default.
thagrol
Mon Jun 14, 2021 6:08 pm
See the output from
man mount.cifs
More specifically:
So it is. My bad. Sorry.
