Ewal
Tv-out does not work with USB boot
Wed Jun 09, 2021 11:31 pm
So I had a 7" car lcd that I wanted to make a little portable game machine with. I got a 60gb ssd for quick loads and discovered that the pi wont boot from usb with enable_tvout=on in the config.txt file. If I delete it, it will boot, even # in front of it will stop the boot, needs to be totally deleted. Just to check I used a microsd and it works like a charm, just MUCH slower boot times, anyone have any ideas?
rpdom
Re: Tv-out does not work with USB boot
Thu Jun 10, 2021 7:30 am
Very odd. There's a few more things I would try:
* Note the size of the file (in bytes) before and after making the changes.
* Try misspelling the option, maybe enable_vtout=on, or something.
* Replace it with something completely different.
* Change which line of config.txt it is on
* Copy the config.txt to a new file. Delete or rename the old file. Rename the new one to config.txt
I'm thinking it might be some buffer size limitation somewhere. I could be wrong.
Unreadable squiggle
thagrol
Thu Jun 10, 2021 8:37 am
Odd indeed. Can you confirm which model Pi you're using.
I'd also try the "hybrid" approach: /boot on SD, / on SSD.
In brief and assuming a 4B and only one USB drive:
  1. You may need to change boot order in the EEPROM to prioritise SD card over USB.
  2. On the SD card change /boot/cmdline.txt to use root=/dev/sda2
  3. On the SSD change /etc/fstab to use /dev/sda2 for "/" instead of the PARTUUID.
  4. On the SSD change /etc/fstab to use /dev/mmcblk0p1 for "/boot" instead of the PARTUUID.
Backup the existing files before you change them.
I'm a volunteer. Take me for granted or abuse my support and I will walk away
All advice given is based on my experience. it worked for me, it may not work for you.
Need help? https://github.com/thagrol/Guides
thagrol
Thu Jun 10, 2021 8:48 am
A further thought occurs: it might be related to conditional filters in your config.txt if you have any.
Ewal
Fri Jun 11, 2021 1:22 am
It is a pi 4B fully updated. It just flashes green like it is missing boot drive only when the enable TV out is in the config file, it is very strange
B.Goode
Fri Jun 11, 2021 8:04 am
Out of curiosity, I read the supporting documentation -
Ref: https://www.raspberrypi.org/documentati ... t/video.md
enable_tvout (Pi 4B only)
On the Raspberry Pi 4, composite output is disabled by default, due to the way the internal clocks are interrelated and allocated. Because composite video requires a very specific clock, setting that clock to the required speed on the Pi 4 means that other clocks connected to it are detrimentally affected, which slightly slows down the entire system. Since composite video is a less commonly used function, we decided to disable it by default to prevent this system slowdown.
To enable composite output, use the enable_tvout=1 option. As described above, this will detrimentally affect performance to a small degree.
Maybe the clock slow-down is sufficient to break the usb mass storage functionality?
davidcoton
Fri Jun 11, 2021 9:18 am
Or maybe it's the difference between "=on" and "=1", though I thought invalid lines in config.txt were ignored.
And I have no idea why a commented line would prevent booting.
I think there is more to discover here.
thagrol
Fri Jun 11, 2021 11:10 am
Seconded.
@OP: post your config.txt
