josetup123
steady red light and 1 blink when connecting to power source
Mon May 17, 2021 4:30 pm
Good Morning everyone
I just received my rpi4 and i've noticed that im facing the following issue. I'm not able to boot up the device. Plus, at the moment i connect it to the power source it shows on the ACT a rapid blink along with the steady read light. I've also tried jumping the J2 header RUN+GLOBAL_EN AND IT WORKED but again the device is presenting the same issue. Furthermore, I've reinstall the EEPROM using Pi Image and try Raspi Os with 3 different SD card with and without a usb adapter.Finally, I also used different power sources.
There has been few opportunities when the device has been working but know is still stucked in this state.
VIDEOS:
https://drive.google.com/drive/folders/ ... sp=sharing
Thanks in advance
Mero
Re: steady red light and 1 blink when connecting to power source
Wed May 19, 2021 2:04 am
I had one green blink when connecting to power system, because I forgot to format usdcard to right filesystem.
