stefan73
ssh connection refused
Tue May 18, 2021 10:12 am
on 2021-03-04-raspios-buster-armhf-lite I try to login via ssh via USB but always get "connection refused.
What I did:
  • mounted the SD-card with the image and created the file "ssh" in boot
  • added a line "dtoverlay=dwc2" at the end of config.txt
  • added " modules-load=dwc2,g_ether" after "rootwait" in cmdline.txt
  • booted rpi connected by USB to my Ubuntu-Laptop
On Ubuntu I had to connect the rpi to the network. So I ...
  • sudo ifconfig to find out the new connection (it was "enx9a29d9305b78")
  • sudo ifconfig enx9a29d9305b78 192.168.178.11 netmask 255.255.255.0
ping worked, I could also access the webserver of the rpi by IP 192.168.178.11
ssh pi@192.168.178.11 always gave "connection refused.
ssh-keygen -R 192.168.178.11 didn't change anything.
What did I wrong?
Thank you!
B.Goode
Re: ssh connection refused
Tue May 18, 2021 11:46 am
What I did:
What did I wrong?
Thank you!
What model of RPi board is involved here?
"ping worked, I could also access the webserver of the rpi by IP 192.168.178.11"
How was that webserver installed and configured? Do you have a locally connected keyboard and display to give you direct access to the RPi?
What do you believe to be the IP address of your Ubuntu laptop?
stefan73
Tue May 18, 2021 12:51 pm
Ups, it's a Zero V.1.3.
The IP of my Laptop is 192.168.178.33
The web-server was preinstalled.
Unfortunately I don't have a keyboard for the pi, but I could connect the hdmi-out.
thagrol
Tue May 18, 2021 1:29 pm
If by "on ubuntu" you mean on your laptop, that's where your mistake is. That's the IP address of your laptop's end of the g_ether conection. You're pinging the laptop and trying to ssh into it.
Loading g_ether creates two usb interfaces, one on host and one on the Pi. Both need to be configured.
I'm not going to go over this (yet again) so a read of my guide here is probably a wise move on your part: viewtopic.php?f=91&t=306121&p=1851130#p1851130
I'm a volunteer. Take me for granted or abuse my support and I will walk away
All advice given is based on my experience. it worked for me, it may not work for you.
Need help? https://github.com/thagrol/Guides
B.Goode
Tue May 18, 2021 3:16 pm
I though this sounded odd, so I have just done a trial installation of RasPiOS Buster [32] Lite to check...
There is no webserver configured or started by default with this image of RasPiOS Lite.
I strongly suspect that you have connected to some other target system running a webserver, NOT your RPiZero.
stefan73
Tue May 18, 2021 4:09 pm
Hi, sorry you are right! At the IP I mentioned it was configured as the rpi via USB my laptop answered. I just try to follow thagrols guide. So obviously I already configured the client-side of my USB-connection. Did not understand yet how to configure the host without having access to it. Need some time...
