BossCoding
[SOLVED] Please help i cant get minecraft to connect with python.
Thu May 13, 2021 9:19 pm
i've tried everything that uses raspberry pi 4. ive installed python 2 IDLE and i still keep getting this error:
File "<pyshell#1>", line 1, in <module>
mc = minecraft.Minecraft.create()
File "/usr/lib/python2.7/dist-packages/mcpi/minecraft.py", line 171, in create
return Minecraft(Connection(address, port))
File "/usr/lib/python2.7/dist-packages/mcpi/connection.py", line 17, in __init__
self.socket.connect((address, port))
File "/usr/lib/python2.7/socket.py", line 228, in meth
return getattr(self._sock,name)(*args)
error: [Errno 111] Connection refused
after i use this code:
from mcpi import minecraft
richonguzman
Re: Please help i cant get minecraft to connect with python.
Fri May 14, 2021 4:30 am
what are you trying to achieve?
scotty101
Fri May 14, 2021 7:56 am
The Getting Started with Minecraft Pi guide specifies that you should be using Python 3 (IDLE) not Python 2.
https://projects.raspberrypi.org/en/pro ... craft-pi/1
I'm guessing that you have opened minecraft-pi already.
BossCoding
Fri May 14, 2021 5:21 pm
What are you trying to achieve?
my goal is to start placing blocks with code and help others.
and i tried every answer ive seen.
i still can't crack it
BossCoding
Fri May 14, 2021 5:22 pm
i tried it... but i still get the refused connection from python 2.
BossCoding
Fri May 14, 2021 5:25 pm
Please get back to me when u can.
Fri May 14, 2021 8:41 pm
https://magpi.raspberrypi.org/issues/27
There's some code in there that I wrote in a previous life.
BossCoding
Fri May 14, 2021 10:44 pm
do you remember which page the code was on???
BossCoding
Fri May 14, 2021 10:45 pm
wait a sec... found it.
BossCoding
Fri May 14, 2021 10:47 pm
question... is this done through the normal terminal???
Fri May 14, 2021 10:52 pm
Normal GUI, normal LXTerminal.
Some of the set-up stuff isn't needed since Minecraft PE 0.9 is pre-installed on some versions of Raspbian and RaspiOS.
NOTE: Minecraft PE 0.9 has been unsupported since 2013 and was dropped by Mojang/Microsoft in 2015.
BossCoding
Fri May 14, 2021 11:03 pm
Think i finally cracked it! thanks Dougie :mrgreen: :mrgreen: :mrgreen: !
BossCoding
Fri May 14, 2021 11:38 pm
well, at least it still works!
