generalveers
Hostnames don't resolve until reboot
Sun May 09, 2021 6:29 pm
I'm running two Pis (on Buster) in my house, each of which has a static IP and a unique hostname.
The problem is that I can only sometimes connect by using [hostname].local. For no reason I can discern, the Pis will randomly stop responding to the hostnames and only respond to the IP address.
When I reboot, the hostname works again...but eventually stops responding to VNC, SSH, ping, etc.
One Pi is connected by ethernet, the other by wifi. Seems to make no difference -- they both suffer from this problem.
I confirmed that avahi-daemon is running and also tried editing /etc/hosts, but no help.
Obviously, this isn't an emergency or even a big deal -- I can still connect just fine through the IP addresses. But it's weird! So I'm trying to figure it out.
Any thoughts?
epoch1970
Re: Hostnames don't resolve until reboot
Sun May 09, 2021 7:42 pm
Which OS is it ?
hal8000
Sun May 09, 2021 7:48 pm
What host system are you trying to communicate with your RPi's?
If its windows you need to modify the windows host file which will be somewhere like
C:\Windows\System32\drivers\etc
If you're on linux or FreeBSD then its in /etc/hosts
copy and paste your hosts file on your next post so someone can help you
generalveers
Sun May 09, 2021 8:49 pm
Which OS is it ?
I'm on either iOS or macOS.
The weirdest thing is that it works on reboot, but then eventually stops. I can't figure out if it's a Pi problem or something with my router.
thagrol
Sun May 09, 2021 9:45 pm
Nope. Not when using avahi/mDNS. Those don't use the hosts file.
I'm a volunteer. Take me for granted or abuse my support and I will walk away
All advice given is based on my experience. it worked for me, it may not work for you.
Need help? https://github.com/thagrol/Guides
epoch1970
Sun May 09, 2021 10:24 pm
Which OS is it ?
I meant, are you running raspios? Publishing the name and address can be achieved in various ways under Linux. OTOH I’d say the current raspios release uses avahi, but I’m not certain a separate process is spawned to publish the address. If it’s a separate process, it’s not impossible it dies.
The normal reason for the name to cease being resolved is for the publication/process to be stopped because the network interface went down.
generalveers
Sun May 09, 2021 11:57 pm
Which OS is it ?
Oh! Oops, sorry! Running Raspian Buster in both cases. What you say makes a lot of sense. I wonder what could be taking down the network interface and why.
RonR
Mon May 10, 2021 12:22 am
I done use *.local, so I'm shooting from the hip here.
The avahi-daemon incorporates the assigned hostname in its process name display:
root@raspberrypi:~# ps ax | grep avahi
  399 ?        Ss     0:00 avahi-daemon: running [raspberrypi-2.local]
These hostnames work as expected between two Raspberry Pi 4B's running Buster here. If I reboot either Raspberry Pi, however, the hostname frequently changes. Could it be this is what's happening to you? When you get no response, go to that device and check it's process name and see if it's changed on you. Surely there must be a way to get consistent naming, but this is not an area I'm familiar with.
generalveers
Mon May 10, 2021 1:40 am
Oh, wow, yeah -- when I try that, I get the proper hostname, but with a number appended. So, [hostname]-3.local, for example.
That's a good clue. Thanks for the suggestion!
MiscBits
Mon May 10, 2021 2:18 am
Are you running 2.4 and 5Ghz WiFi by any chance?
I've seen issues where some home routers 'forget' device names on the other network. BT have just been called out on this (see here) and I know tp-link have similar issues.
I'm pretty sure the older Airports (flat pizza-box style) APs from Apple have the same glitch but not 100% convinced I've tracked it down to the APs or an IGMP snooping issue.
It may be worth turning IGMP snooping off - sorted out a HP printer 'dropping off' the network here.
Is a computer language with goto's totally Wirth-less?
epoch1970
Mon May 10, 2021 8:51 am
If a number is appended, it means that there is a duplicate of the host name already published. The name is taken, so the new host appends -1, the next -2 etc.
Reality looks to be a bit more fuzzy, I’ve seen “name-5” and “name-6” when 2 host names collide...
Perhaps try changing the hostname of the Pi (via raspi-config)?
generalveers
Mon May 10, 2021 1:18 pm
Thanks for the advice! I'm using an eero router, which I don't believe supports IGMP snooping, but I'll take a look!
generalveers
Mon May 10, 2021 1:20 pm
Ah, yes, this makes perfect sense. (Well, except I'm not sure HOW or WHY this is happening, but I understand that it IS happening.)
To be clear: When I go into raspi-config, the hostname is still the original, with no number appended. So it's not a matter of changing it from, say, hostname-2 back to hostname, but more that I am changing it from hostname to newhostname, right?
epoch1970
Mon May 10, 2021 1:33 pm
Yes, try extremelyimprobable or something like that as a host name. Then reboot.
If it gets advertised as extremelyimprobable-1.local, then there is a networking problem, and for some reason the Pi hears its own publication and collides with itself...
generalveers
Mon May 10, 2021 1:34 pm
Will do. It sometimes takes several days for the problem to show up, so I may be radio silent for a little while. Thanks for your help!
generalveers
Wed May 12, 2021 11:43 am
I'm back to announce that after responding to thisisanewname.local for a couple of days, it no longer responds.
When I run ps ax | grep avahi, I get thisisanewname-2.local.
So, yeah, something is causing a collision, but I have no idea what.
