Reezaro
Problem with Adafruit_CircuitPython_dht and Reading DHT22 Sensor
Sat May 08, 2021 4:34 am
I am trying to read temp and humidity from AM2303 (DHT22) by using adafruit_CircuitPython_dht libaratry in RP4.
When I run my code as a main every thing is OK. But when I import the function and call it from another program, it keeps showing the below error regarding pin.py GPIO.setmode.
File "/usr/local/lib/python3.7/dist-packages/adafruit_blinka/microcontroller/bcm283x/pin.py", line 4, in <module>
GPIO.setmode(GPIO.BCM) # Use BCM pins D4 = GPIO #4
ValueError: A different mode has already been set!
As I noticed, pin.py is trying to change the GPIO setmode to BCM but apparently it has been set to something different. I checked my whole program and I could not find anywhere to set my GPIO to something.
So, please help me to figure it out what the poblem is and how I should resolve it.
Appreciate you
pcmanbob
Re: Problem with Adafruit_CircuitPython_dht and Reading DHT22 Sensor
Sat May 08, 2021 8:21 am
I am guessing that you have set the GPIO.setmode to board in your program that is using the imported module,
I say guessing because you have not seen fit to post your code, which would have helped us understand the problem.
Reezaro
Sat May 08, 2021 9:30 pm
Thanks for your reply.
I could not post my codes because they are not in one page and if I copied and pasted them here, it would be a really mess up.
I have checked my own written codes and 100% sure I have never set the GPIO mode to board or bcm.
I forgot to mention that I have never used GPIO #4 in my code and that port is free. I use GPIO #21 to read the sensor data.
joan
Sat May 08, 2021 9:43 pm
If you are 100% sure everything is correct why are you asking a question?
If you want help you will have to show the code.
pcmanbob
Sun May 09, 2021 10:09 am
You can post any length of code even pages of it, just use code tags , that will also preserve the indentation that python relies on.
Just copy you code in to your post and add code tags top and bottom like this
Add [code] at the top
for i in range(8):
print "code goes here"
time.sleep(1)
and [/code] at the bottom.
which results in it looking like this
for i in range(8):
    time.sleep(1)
