msiot
Hard drives connected to RPi4 via USB 3 port get randomly disconnected
Tue Apr 27, 2021 7:11 pm
It seems that there are a lot of users having troubles with their storage drives attached to Raspberry Pi, however there is no proper solution of solving these issues. In a lot of topics users reported that their drive disconnects from Raspberry PI.
In this topic I wanna report my hardware and hopefully there is something that can be done about. Sorry that it is a bit long, but I think it is better if I provide as more information I can.
I own an Icy Box IB-RD3621U3 that is actually a box with its own power supply, a USB 3.0 connection with UASP support that can host 2 x 3.5 Inch SATA HDDs.
In my configuration I connected 2 x WD Red NAS Drive of 4 TB - WD40EFRX. Both HDDs are formatted in ext4 and the RAID support is disabled.
My purpose was to setup a simple NAS server solution where I can backup my files. By doing some tests I was quite satisfied regarding its performance as I could almost reach the maximum speed the 1Gbps Ethernet port and I could also use hd-idle to stop spinning the disks after 10 min of inactivity.
The trouble that I have is that randomly it resets or disconnects from Raspberry Pi.
To be more concise, I'm going to explain the exact behaviour. I connect the box to RPi and can play media for 2-3 hours without issues, leave it to rest for some other hours (3-4 hours) where disks won't be spinning. After that I can again access files and the drives start spinning and everything works as expected. Next day if I'm luck it will still work but most probably after 2 days the drives are not accessible anymore.
I tested this during more than 1 year and with several kernels or Raspbian releases including the latest releases.
I tried to add the quirks provided in this topic.
Nothing of these couldn't help me fix the issue and it is annoying and useless having such kind of unreliable system.
Some additional informations:
lsusb
Bus 002 Device 016: ID 152d:0562 JMicron Technology Corp. / JMicron USA Technology Corp.
Bus 002 Device 001: ID 1d6b:0003 Linux Foundation 3.0 root hub
Bus 001 Device 002: ID 2109:3431 VIA Labs, Inc. Hub
# UASP is disabled
lsusb -t
/:  Bus 02.Port 1: Dev 1, Class=root_hub, Driver=xhci_hcd/4p, 5000M
    |__ Port 2: Dev 16, If 0, Class=Mass Storage, Driver=usb-storage, 5000M
/:  Bus 01.Port 1: Dev 1, Class=root_hub, Driver=xhci_hcd/1p, 480M
    |__ Port 1: Dev 2, If 0, Class=Hub, Driver=hub/4p, 480M
# entries fstab
UUID=139a6cdc-e380-45e4-971b-34f6b86aa47f /media/usb0 ext4 noauto,x-systemd.automount,x-systemd.device-timeout=10,auto,users,rw,nofail 0 0
UUID=c757f3f9-38bd-4634-888b-92057f0b500b /media/usb1 ext4 noauto,x-systemd.automount,x-systemd.device-timeout=10,auto,users,rw,nofail 0 0
lsblk -o NAME,SIZE,UUID,MOUNTPOINT,TYPE,REV,STATE,FSUSED
sdd          3.7T                                                 disk 0106 running
└─sdd1       3.7T 139a6cdc-e380-45e4-971b-34f6b86aa47f            part
sde          3.7T                                                 disk 0106 running
└─sde1       3.7T c757f3f9-38bd-4634-888b-92057f0b500b            part
The disks should normally mount to /dev/sda1 and /dev/sdb1, however after it disconnects takes the following /dev/sd* or in some cases they don't appear to be mounted anymore or just 1 of the disks mounted.
The solution to overcome this is that I manually unmount and mount again the disks or disconnect the usb cable and connect again. Everything will come back to normal in this case, but the situation repeats after 1-2 days or sometimes earlier.
Please let me know if I can provide additional information for debugging this or give me suggestion of what can I try.
I was thinking of creating a docker container that is watching the logs and remount partitions, however would like to get your opinion beforehand in case it can be solved in a different way.
LTolledo
Re: Hard drives connected to RPi4 via USB 3 port get randomly disconnected
Thu May 06, 2021 9:11 pm
the usual suspect: JMicron
ever tried ones with ASMedia?
Some people be like:
ejolson
Thu May 06, 2021 9:35 pm
lsusb
# UASP is disabled
lsusb -t
# entries fstab
Can you verify whether the USB enclosure is accidentally feeding powering power to the Pi backwards through the USB cable?
I think the noise from the fighting which occurs when two power are connected together like that may be responsible for the recurring disconnects you see.
If anyone has an easy way way to check if an enclosure or hub has this fault, it would be great to hear about it.
Gavinmc42
Fri May 07, 2021 1:08 am
What is the current situation with JMicron and the VL805?
https://github.com/raspberrypi/rpi-eeprom/issues/316
VL805 firmware
https://www.raspberrypi.org/documentati ... teeprom.md
Nice to know when this changed. What revision does OP have?
The VLI805 USB firmware EEPROM image - ignored on 1.4 board revision which does not have a dedicated VLI EEPROM
I'm dancing on Rainbows.
ejolson
Fri May 07, 2021 2:47 am
VL805 firmware
I don't know. Fido loaned me a 4-bay USB enclosure because the SMR drives were causing problems with the ZFS port for the SuperPET. It identifies as
JMicron Technology Corp. / JMicron USA Technology Corp. External Disk 3.0
and has never given any trouble on a Pi, though right now it's connected to x86 server that provides backing store for the 2U Pi Cloud.
My impression is the manufacturer of that 4-bay enclosure is third tier while ICY DOCK is possibly fourth tier (whatever that means). The fact that the ICY DOCK mentioned in the original post of this thread works well for a couple days at a time is promising; however, it would be nice if the stability problems could be fixed. I suspect power back feeding or an insufficient supply are the more likely problems, but who knows.
Bartolo
Fri May 07, 2021 1:40 pm
Isn't this related to this problem? If so there is kind of a solution.
msiot
Mon May 17, 2021 6:57 pm
I could read in many places that indeed JMicron is a bad chip. I don't have one with ASMedia and would like to give a try, however doesn't seems be an easy option to connect 2 x HDDs of 3.5 inch. Would be great the issue can be solved using my current setup.
Would be nice to know how can I check that. I tried to measure the voltage between first and forth usb pin (usb cable disconnected from pi) and don't get any voltage. I think this happens because when I pull out usb cable, HDDs and cooler stop spinning (suspend mode).
VL805 firmware
Mine is identified as:
Bus 002 Device 026: ID 152d:0562 JMicron Technology Corp. / JMicron USA Technology Corp.
and in syslog I can see it as
Product: JMS56x Series
Manufacturer: JMicron
SerialNumber: RANDOM__1ACDEBB6A084
I already tried the quirk, the quirk is applied but still it doesn't help.
