klatox
Extraordinarily slow Samba speed
Mon Apr 19, 2021 4:34 pm
Hi all,
I recently successfully configured a Samba share on my new Pi, however, writing to the share is extremely slow.
The share is a brand new Samsung T7, formatted as ntfs, and connected via USB 3 port.
When writing to the drive from my win10 machine, I’m seeing 2MB/s at the most.
I tested writing to the drive locally from the Pi using the dd command and it gave me 160MB/s.
The Pi is directly connected to my router via a cat6 cable and the WiFi is disabled. My win10 machine is on 5Ghz WiFi.
Any idea what could be wrong?
ejolson
Re: Extraordinarily slow Samba speed
Mon Apr 19, 2021 4:43 pm
Hi all,
That looks like a networking problem. What happens when you connect the laptop over wired networking?
klatox
Mon Apr 19, 2021 5:33 pm
Hi all,
Good question, unfortunately the win10 machine is a desktop and is in another room entirely, so I’ll have to disconnect everything and test it that way. But this got me thinking, I wonder if there is some
win10 wireless adapter setting or driver issue going on.
hortimech
Mon Apr 19, 2021 7:03 pm
There are problems with rpi's and some USB3 connected drives, could this drive be one ?
However, the main problem is probably the filesystem, NTFS is for Windows, you will get better performance with a Linux filesystem, ext4 for instance.
LTolledo
Mon Apr 19, 2021 9:04 pm
NTFS + Samba is SLOW!!
EXT4 + Samba is FASTER!
and as stated by hortimech above, a certain combination of hardware will also degrade performance.
some files WILL show slow transfer rate, even with EXT4 + Samba, and with the right hardware combination
on the image below, the transfer was made using a single 5GB mkv file
the hardware were:
1. bare Seagate Baracuda 2TB drive, one formatted NTFS and the other EXT4 (connected one at a time)
2. Eluteng blue SATA to USB3.0 adapter cable, connected to the USB3.0 port of RPi4B
3. microSD-boot RPi4B-4GB with RPiOS32 Lite and Samba, Ethernet LAN connection.
4. the w$10 connection is also via Ethernet LAN
w10 to RPi4B-4G samba share file transfer spinning rust NTFS.jpg (17.74 KiB) Viewed 144 times
w10 to RPi4B-4G samba share file transfer spinning rust EXT4 .jpg (17.17 KiB) Viewed 144 times
there was another forum member who had problem with slow samba transfer rate....
the forum member was using a certain Seagate Backup unit.
Some people be like:
klatox
Mon Apr 19, 2021 9:54 pm
the hardware were:
As a test I tried a USB flash drive formatted as ext4 and it was also extremely slow, probably just as slow as the ntfs share.
I also tried formatting my T7 as ext4 and I'm actually getting worse speeds than with ntfs...less than 1MB/s over both samba and sftp
klatox
Tue Apr 20, 2021 3:28 am
I tried the usb quirks adjustment in the sticky thread, unfortunately it did not alleviate the issue.
hortimech
Tue Apr 20, 2021 7:55 am
Then it looks like your problem is the USB drives you are using, try yet another drive, ext4 should be a lot faster.
