I have no idea what it is, or if it is usable without it. Does anyone know what it is? Can I still use it safely?
(It is about 2mm by 1mm)
[attachment=0]0DFC42F9-D7AF-488A-AB9B-71CF218E9C53.jpeg[/attachment]
Something small fell off my raspberry pi 4
- Attachments
- This is a magnified photo
- 0DFC42F9-D7AF-488A-AB9B-71CF218E9C53.jpeg (127.47 KiB) Viewed 600 times
Re: Something small fell off my raspberry pi 4
From the information you have made available, no-one can determine whether or not your RPi4B will operate without that part. However you can be assured that you will be in no personal danger if you try to use your RPi4B in its current state.
Are you sure you are not guilty of a terminological inexactitude by writing that it "fell off".
Thanks for the help!drgeoff wrote: ↑Mon Feb 22, 2021 2:32 pmFrom the information you have made available, no-one can determine whether or not your RPi4B will operate without that part. However, you can be assured that you will be in no personal danger if you try to use your RPi4B in its current state.
All I did was put a case on then I found it on my desk. It could have been me.
(it has also been operating as a server, which could have damaged it)
- davidcoton
- Contact: Website
Can you post a photo showing where on the board it fell from? If you can't see the gap, then good hi-res photos of both sides of the board.
Also, exactly which Pi4 (memory size and board revision)? Normally you find out with
but that doesn't help if the Pi doesn't work.
The full schematic is not published, so we may need help from a Pi engineer to identify the part.
cat /proc/cpuinfo
- mahjongg
- Forum Moderator
It looks like a 1206 ferrite, or ceramic capacitor, but I'm puzzled by the black mass around it, is that plastic?
are you sure it came off the PI?
the black stuff Is just mess on the side since its zoomed in so much
I don't use anything else with an exposed board, so it could only have come off the pi.
It is has 4gb ram. The board revision is ‘c03111’davidcoton wrote: ↑Mon Feb 22, 2021 2:43 pmCan you post a photo showing where on the board it fell from? If you can't see the gap, then good hi-res photos of both sides of the board.
Also, exactly which Pi4 (memory size and board revision)? .
Images of pi:
https://ibb.co/n0Hw2NY
https://ibb.co/71CtTTj
- davidcoton
- Contact: Website
A side-on close-up photo of that site and the part you found might help -- or not.
EDIT: see gordon77's post below. I should have gone to a decent optician.
Here... something to do with the power supply?
I can't be certain but both lands maybe OK for resoldering..
- Attachments
- IMG_20210222_170940.jpg (78.63 KiB) Viewed 411 times
- IMG_20210222_162900.jpg (166.05 KiB) Viewed 442 times
Will it be ok without it? I don’t know how to solder.gordon77 wrote: I can't be certain but both lands maybe OK for resoldering..
Looking at the schematic, and pictures of the pi4, it maybe C1 on the incoming 5v supply. Probably a bit of smoothing ?.
It may work OK without it.
I can't guarantee any of this.
- Attachments
- IMG_20210222_213316.jpg (28.94 KiB) Viewed 348 times
gordon77 wrote: Looking at the schematic, and pictures of the pi4, it maybe C1 on the incoming 5v supply. Probably a bit of smoothing ?.
It does power on and it does workgordon77 wrote:
I don't know without knowing what it does. If you have powered it and all ok then I wouldn't worry about it.
That's good. Maybe someone from RPF could confirm it is C1.
if its indeed C1 and the same thing happened to my RPi4B...
I'd solder in a regular 10uF MLCC....
it wont look good at the bottom board.... but.... its the bottom board anyway...
edit some typo.... sorry..
Some people be like:
- davidcoton
- Contact: Website
Two options:
- Time to learn (though this repair is NOT a beginner task!)
- Phone a friend
I would not suggest attempting to learn to solder via a fairly small chip package...davidcoton wrote: ↑Tue Feb 23, 2021 11:24 amTwo options:
- Phone a friend
If it is a decoupling cap, and the Pi boots and runs fine without it, I would not worry about it. Shorting out the 5V rail to ground with a solder blob will produce suboptimal results.
- Burngate
- Contact: Website
Also of note: C1 decouples the feed to the LDO that feeds the analogue audio circuitry; if you don't use the 3.5mm trrs socket, you won't gain by fixing it!
Also, shorting out C1 with a solder blob will drive 2.5W through R2, resulting in a sparkler.
