bullen wrote: ↑Mon Jul 06, 2020 11:37 pm
What did you use to write the images?
I used to use Etcher, but lately I've been using Raspberry Pi Imager.
However, both of these work from the command line with an extracted .img file.
sudo dd if=2020-05-27-raspios-buster-lite-armhf.img of=/dev/sdb bs=4M;sync
sudo cp 2020-05-27-raspios-buster-lite-armhf.img /dev/sdb;sync
This works as well, and is a bit tidier because you don't need to extract the .zip file first.
sudo su
unzip -p 2020-05-27-raspios-buster-lite-armhf.zip >/dev/sdb;sync
Note on my system the SD card reader is /dev/sdb so you will have to correct for your system.
It's not the screen or anything else because I use everything already and it all works!!!
If it all works, then what are you complaining about?
Somewhere along the line the kid friendly computer turned into you must have multiple days just to write the OS on a SD card... the train is officially derailed! It's so bad most people now have PTSD from failing to write SD cards!
That is absolutely not true for most people!
I got my Pi4s in July 2019, less than a month after release, and I haven't had trouble writing any of the images. I don't know why you are having problems, but since you aren't supplying any information needed to troubleshoot your issues I can't help.
You can continue to blame your troubles on others and your problems will continue as well. If you decide you actually want help, then I suggest you cooperate with the people who are trying to help you. Good luck.
